Gluing PVC Repair Couplings - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-27-2015, 09:49 PM   #1
Rewards Points: 76
Gluing PVC repair couplings
Reading another thread it was mentioned to use a PVC repair coupling. I've always wondered what the proper way to glue a repair coupling is? How do you glue and then slide it and make sure you have enough glue to make a leak proof joint?
ponch37300 is offline   Reply With Quote
Old 10-27-2015, 10:55 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,878
PVC repair couplings are not like a copper slip coupling.
They are kind of a repllacement pipe with a compression type coupling on both ends.
No glue involved.
MTN REMODEL LLC is online now   Reply With Quote
Old 10-27-2015, 11:29 PM   #3
griz's Avatar
Rewards Points: 572
No glue involved.
Handing out plumbing advice now, eh????
You back home or in So Cal?
griz is offline   Reply With Quote
The Following User Says Thank You to griz For This Useful Post:
MTN REMODEL LLC (10-29-2015)
Old 10-27-2015, 11:51 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 290
http://www.homedepot.com/p/NIBCO-2-i...PHD2/100677975
The glue process is basically the same. Use a slow set glue
Old 10-28-2015, 08:31 AM   #5
Rewards Points: 18,990
Before installing hold the coupling against the pipes and make a mark with it needs to be to have about equal coverage on both ends.
Slide it over one side.
Prime, then glue.
Slide it in place and give it a slight twist to spread the glue in the joint.
Old 10-28-2015, 06:05 PM   #6
Rewards Points: 1,952
Use a lot of primer on the pipe and the coupling to get a real good pre-softning of both then apply glue to both liberally. Once started you must do it very quickly.
Old 10-29-2015, 04:55 PM   #7
Typo error mistake
Old 10-29-2015, 04:59 PM   #8
Hey Griz.... How ya doing.... Your memory is sure doing great.
Just got back from several months at my son's in SoCal.... (We had added 2400 ft onto his old POS two blocks from the beach shack... but we were doing the old 800 ft main house. Replaced all the old CI/supply/ and electrical, new cabinets/counters/appliances/backsplases and flooring. Almost done)
(ps to the OP... Guess I've never used a "hub" for a glue slip coupling on PVC... always used the "pipe style" coupling... seems to me that you had better be perfectly aligned, or with one free end rather than locked in a ditch... but maybe PVC is more forgiving than copper with a slip coupling. ????
Hope ya doing well ...
Best
Peter
Old 10-29-2015, 05:12 PM   #9
Prime, then glue.
Joe.... Actually I'm kinda confused.... if you slide it over one side (with glue already applied I assume.... otherwise how do you get the first side glued) do you really have ability to slide it back over the other side and still get a good "weld".....
I'm sure your right... and I'll have to try it.
Old 10-30-2015, 05:59 PM   #10
Yes because your pipe your sliding to has glue. I use proflex couplings on one side and glue only the other side. The odds are your slip stuff will leak.
But I will always let you live and learn.
The Following User Says Thank You to Ghostmaker For This Useful Post:
MTN REMODEL LLC (10-31-2015)
Old 10-31-2015, 04:02 PM   #11
Thanks Ghost..... That makes better sense at least to me.
Best
foundation Repair Questions njhammerman Building & Construction 8 02-13-2014 07:18 AM
questionable flange repair adcoje Plumbing 7 06-24-2013 09:26 AM
Req opinions on professionally completed drain repair. Mig3 Plumbing 8 05-19-2013 12:53 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Relace vs Repair: PVC heating exhaust joint mcgrete HVAC 2 01-16-2011 09:55 AM
