Glacier Bay All In One Sink Faucet Low Pressure -- Aerator Clean - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-14-2015, 02:07 PM   #16
Rewards Points: 6
*edit* Double Post
ohyeahthatchick is offline   Reply With Quote
Old 09-23-2015, 06:45 AM   #17
Rewards Points: 2
worked
Thank you sooo much... there were two in mine also... water pressure is perfect now!!!
melissarockey is offline   Reply With Quote
The Following 2 Users Say Thank You to melissarockey For This Useful Post:
jmon (09-23-2015), oh'mike (09-23-2015)
Old 09-23-2015, 02:13 PM   #18
Rewards Points: 1,932
Thats a check valve you should have one installed to protect your drinking water if you leave the spray in the sink basin.
Ghostmaker is online now   Reply With Quote
Old 09-29-2015, 02:13 PM   #19
Rewards Points: 6
A - why would you leave the sprayer in the basin? B - the pull back on the thing prevents the sprayer or even being able to sit in the basin, it pulls it back up into the faucet. C - my previous faucet for the past 10 years didn't have one at all and I'm still alive. In fact I'm fairly sure none of the faucets I grew up with for the past 33 years ever had one.
The Following User Says Thank You to ohyeahthatchick For This Useful Post:
MaineLL (09-29-2015)
Old 04-21-2016, 06:27 PM   #20
cyg
Rewards Points: 2
Re: Glacier bay all in one sink faucet low pressure -- aerator clean
ohyeahthatchick thanks for that info.........who would think to look in there 1st ? it helped a bit but its nothing like it was.......its almost usable now ........the flow/pressure @ that spot was so ridiculous that you had to turn it on only partially or else it would splash everywhere.........Its a brand new glacier bay pull down spay sink faucet.......it sounds crazy but I had the same exact issue with a GB shower diverter......did remodel.....had to rip out the wall to change the damn thing......I had thought it was just a defective valve housing after replacing the cartrige....home depot gladly let me switch it......but still NFG so I replaced the whole diverter .......& still no good... it was simply a "bad model".....a "watersense" compliant government conspiracy bull**** model.......the actual innards were just too small......& I mean ....in no way could you use it to shower .....if u did u would use more water in the long run cuz it would take 3 hours to get clean....& the pressure at that location was great with the old style valves.........so i changed it out for a delta ......& its ok .....about 75% of what it can be......but defiantly usable......so they actually make them nowadays so that you cant just remove constrictors and/or anything else(which was always the 1st thing I'd do)........the funny thing is that, I bet most of the ppl that come up with these compliance ideas live in old mansions with 5gal per flush plumbing........so in conclusion apparently its the govt's job to control how much water we need to flush a dump & wash etc......just thought I'd share
cyg is offline   Reply With Quote
The Following User Says Thank You to cyg For This Useful Post:
oh'mike (04-21-2016)
Old 06-17-2016, 12:04 PM   #21
Rewards Points: 2
Thanks SO much for this information. We just installed the sink in April and I've been looking for the flow restrictor(s) ever since. While I believe firmly in conservation (and I don't think strict regulations in the midst of profound drought conditions, especially in SoCal, are "nanny state" indicators), one does need some water pressure in the shower and in the kitchen sink. So better to have shorter showers and more consciously careful dishwashing than no water pressure. Thanks again!
RevLauren is offline   Reply With Quote
The Following User Says Thank You to RevLauren For This Useful Post:
oh'mike (06-17-2016)
Old 08-13-2016, 03:13 PM   #22
This site and its contributors were extremely helpful and in case you need a visual on where these restrictors can be found, here is an image of where and what to look for.
Glacier bay all in one sink faucet low pressure -- aerator clean-image_1471119059118.jpg   Glacier bay all in one sink faucet low pressure -- aerator clean-image_1471119200888.jpeg
Shimmydiva is offline   Reply With Quote
Faucet Leak below kitchen sink and from the Delta faucet: Replace or Repair? spyboy Plumbing 14 05-13-2014 07:03 PM
Kitchen sink faucet - putty or silicone, and where? nthdegreeburns Plumbing 11 07-24-2012 03:45 PM
Pressure Change on Outdoor Faucet mrhudock Plumbing 0 04-11-2011 09:34 PM
vessel sink drain and faucet Katmac Plumbing 17 10-11-2010 08:12 PM
Pressure Balanced faucet question scp Plumbing 2 01-07-2007 05:15 PM
