Glacier Bay 4in Faucet High Flow Aerator? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-24-2016, 09:58 PM   #1
Glacier bay 4in faucet high flow aerator?
Hello, I recently moved into an apartment with a bathroom sink that appears to be this model: http://m.homedepot.com/p/Glacier-Bay...8101/202043750
The aerator says 1.5gpm, and looking online I could only find replacement aerators with the same flow rate. Does a higher flow aerator exist?
Otherwise, does anyone know how to remove the flow restrictor? In whatever form it might be?
Alex1489 is offline   Reply With Quote
Old 05-24-2016, 10:22 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 168
Re: Glacier bay 4in faucet high flow aerator?
Hi Alex, welcome to DIY Chatroom. The EPA sets the required maximum flow rate for lav faucets at 1.5gpm. That's why you can't find a larger aerator.
Old 05-25-2016, 05:03 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
I have taken a 1/64" drill bit and drilled several holes thru the aerator. Start with 2 holes and add more if you want more flow. When you move out install a new aerator.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 05-25-2016, 02:54 PM   #4
Thanks for the tip, rj. I might give that a shot.
TheEPlumber, I feel like my most other bathroom sinks I use have much higher flow than I'm experiencing with this sink.
Maybe it's actually running at less than 1.5gpm?
Looking for advice re low flow from shower cold faucet Rav Plumbing 4 12-12-2015 08:17 AM
Kitchen faucet threads - install swivel aerator USEYOURHEAD Plumbing 2 10-09-2010 12:30 PM
High Flow Shower Heads Carloscda Plumbing 1 03-18-2010 09:16 AM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-15-2009 11:09 PM
Air Lock in hot water line? tqwood Plumbing 3 03-15-2008 11:26 PM
