Gas Water Heater Installation Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-08-2017, 09:17 PM   #1
Rewards Points: 2
gas water heater installation question
Upon inspection of the 30 gallon gas heater in a rental I found that the inlet line and the exit(hot) lines are hooked up in reverse. They appear correct but when hot water is used in the house the pipe connected to the cold water inlet on top of the tank heats up. That is, the water flows in reverse. It has been this way for years and no one has complained.
Obviously I intend to correct this but wonder just how this backward flow affects the gas use and/or the efficiency. I also wonder just what idiot did this installation, but I doubt that I will ever find that out.
Anybody else ever found this? Comments are appreciated.
jeerlinger is offline   Reply With Quote
New-ish electric hot water heater blowing fuses. roasted Electrical 33 01-11-2017 01:24 PM
New hot water heater issue with water quality and potential resolutions biggerdaddynj Plumbing 11 04-13-2016 10:17 AM
Need input on indirect fired water heater install. A Squared HVAC 13 11-23-2013 04:42 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
