Gas Tankless Venting - Will Existing Tanked Venting Work? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By TheEplumber
  • 1 Post By BIG Johnson
Old 06-22-2017, 10:08 AM   #1
Rewards Points: 42
Question
I have a gas tanked water heater in an upstairs closet venting upward out through the roof. I'm considering replacing it with a Gas Tankless system.
Years back I was told that venting for my existing water heater would need to be replaced with heavier gauge pipes if I were to go tankless. Was this a true statement? Is it still the case? Can I replace my gas tanked heater with a tankless without changing the existing vents. Any recommendations on a tankless system? Where could I find installation steps for this?
TIA,
Patrick
dreiding is offline   Reply With Quote
Old 06-22-2017, 10:10 AM   #2
Rewards Points: 4,804
Re: Gas Tankless Venting - Will Existing Tanked Venting Work?
Have you done the math to ensure a tankless will work? They are generally much better on paper than in real life.
stick\shift is offline   Reply With Quote
Old 06-22-2017, 12:05 PM   #3
Breakin' Stuff
Rewards Points: 1,374
Vent sizing is based on BTU's. A tankless is going to be way more BTU's than one with a tank.
Renovations to my 1947 home can be followed here: www.schlosserhouse.com
Bret86844 is offline   Reply With Quote
Old 06-22-2017, 05:48 PM   #4
Rewards Points: 898
TIA,
Patrick
There are many different models of tankless. But I can tell you for sure that venting will need to be redone.
BIG Johnson is offline   Reply With Quote
Old 06-22-2017, 06:19 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 248
+1
Assuming your current heater is natural draft- you will not be able to use that vent for a new mech. draft tankless. A new vent system will be needed based on the manufacturers installation manual. Perhaps even a different location as well.
BIG Johnson likes this.
Old 06-22-2017, 07:49 PM   #6
Rewards Points: 898
Originally Posted by TheEplumber View Post
+1
Which isn't totally bad. You can hook up most of your new tankless while still using your old tank until the tankless is ready to rock.
TheEplumber likes this.
Tags
tankless water heater , water heater
Install new vent/register into existing duct work? Jughead HVAC 11 12-09-2010 05:08 PM
Adding a stand alone wood furnace to existing duct work vtboy51 HVAC 1 04-01-2009 02:19 PM
Is it right that an owner must be licensed to perform work joey b Electrical 45 12-16-2008 10:16 AM
inspecting existing work bp2 Electrical 9 01-31-2008 05:13 AM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 09:35 AM
