Gas Stove Hookup - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-11-2015, 08:40 PM   #1
Rewards Points: 102
Gas stove hookup
Trying to hookup a 48" KItchenAid gas stove.
I have a 3/4 inch connection going from floor and a 3/4" connection at the stove.
The pressure regulator that I have is 1/2 both sides.
Do I have the correct size Pressure Regulator? If so, what parts do i need to go from 3/4 to 1/2 to 3/4?
Why 1/2" and not 3/4" on both ends?
Lesha22 is offline   Reply With Quote
Old 05-12-2015, 09:23 PM   #2
Reducer couplings 3/4" to 1/2" on each side. Unless it's a huge input the reg should work just fine
gassyplumber is offline   Reply With Quote
Old 05-12-2015, 09:55 PM   #3
Rewards Points: 102
Is this a workaround? Ir is this how all 48" stoves (wolf,thermadir,etc) are setup?
Old 05-25-2015, 06:29 PM   #4
Rewards Points: 996
I assume this is a residential stove, not commercial. The 1/2 " regulator will work just fine. The regulator has an arrow, which points the direction of the gas flow, to the stove. The parts, from supply to the stove should be
Riser from floor
Manual gas valve, should have WOG on the valve someplace. Which means Water, Oil, Gas usage.
Flex gas line, long enough to move the stove for cleaning. I install 48" hoses. Do not connect 2 hoses together.
Regulaltor, with the adaptors mentioned in the previous post
Stove 3/4" gas pipe.
Use a pipe lube on all connections. Use a soap solution to check for leaks.
fireguy is offline   Reply With Quote
Old 05-25-2015, 06:37 PM   #5
Rewards Points: 278
My Wolf specifies 3/4 ID pipe to the appliance with 1/2 connections.
Dan
djlandkpl is offline   Reply With Quote
Old 05-25-2015, 06:42 PM   #6
Rewards Points: 6,320
If someone attempts to sell you pipe bushings to make the size change over tell them no thanks I want bell reducers.
SeniorSitizen is offline   Reply With Quote
Wall Prep for Wood Burning Stove Install Kory Beam Building & Construction 10 04-02-2015 12:24 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 04:54 PM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 09:28 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 05:32 PM
