Gas Regulator Question. - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-04-2016, 10:43 AM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,140
Gas regulator question.
Pretty sure I know the answer to this. Please verify.
Salesman from wholesaler sold me a gas regulator. He stated that the rep told him this is what they use instead of a twin regulator and it will work just fine for a single step application.
Shame on me for not double checking the inlet pressure of the regulator, but I got it all hooked up and adjusted to 10.5" WC and shut the outlet valve off overnight for peace of mind and it slowly crept up over the course of the night while I slept.
Would over-pressure on the inlet cause this?
I'm going to throw this thing at his face.
Thanks.
Journeyman Plumber
Old 12-04-2016, 01:27 PM   #2
Rewards Points: 80
Re: Gas regulator question.
Thanks.
I assume that this is propane. Our code specifies that all such regulators used for fixed appliances need to be dual stage. BBQs are one the the exceptions.
Of course that is usually in the utility side, so I don't get into it much. Not to many MH here.
Cheers!
supers05 is offline   Reply With Quote
The Following User Says Thank You to supers05 For This Useful Post:
Alan (12-07-2016)
