Gas Pipe Configuration - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-26-2015, 11:54 PM   #16
Rewards Points: 6,652
Depending on how easy it is to take it all down. You can take it into a Ace Hardware with the measurements for any piping, and they can cut & thread for you. If you cut it, use a motorized handheld band saw with a Metal/Steel blade. You can also rent the motorized threader/cutter, so you can do them on the fly downstairs.
Any leftover piping, just do like I do. I toss all of my extra stuff that is long enough, up on top of the trusses in my garage. I actually bartered with my plumber, when I had my water heater put in. Because we found some Black Iron & Copper pipe that the original owners had tossed up on top of the trusses.
For some reason with my setup, they got lazy with one section and just used a Black Iron Pressure fitting clamp to join the two sections, instead of threading them, to use a threaded coupling.
Joining thin wall abs pipe to standard abs pipe Homerepairguy Plumbing 3 03-01-2015 11:39 PM
Can't drain water from water pipe to outside faucet hansim4 Plumbing 19 02-23-2015 02:07 PM
Removing pipe wrap around copper pipe steve3847 Plumbing 1 12-25-2012 02:46 PM
Wood-burning stove...connecting stovepipe to ceiling support box Laura J. Building & Construction 23 12-26-2011 12:49 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
