Gas Pipe Adjust - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Ramma247
Old 08-30-2016, 03:07 PM   #1
Rewards Points: 4
Gas pipe adjust
Looking at adjustment of pipe that feeds gas there is a close/open tap currently closed and disconnected but sit too proud so need to adjust down is it as simple as loosen the nut and turn pipe lower and then tighten first post hope picture is visible thanks in advance
Ramma
Ramma247 is offline   Reply With Quote
Old 08-30-2016, 04:06 PM   #2
Rewards Points: 3,218
Re: Gas pipe adjust
Cant tell from the pic. If there is a union the pipe can be adjusted. I dont usually see copper pipe used for gas lines. It looks like its soldered at the elbow.
Please wait for the plumbers to respond.
jmon is offline   Reply With Quote
Old 08-30-2016, 05:15 PM   #3
Rewards Points: 5,536
Re: Gas pipe adjust
Originally Posted by Ramma247 View Post
Attachment 303729
Ramma
I'm visualizing a flare fitting at that location so your suggestion to loosen the nut to make the adjustment is what I would do.
SeniorSitizen is offline   Reply With Quote
Old 08-30-2016, 05:49 PM   #4
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,650
Re: Gas pipe adjust
Looking at adjustment of pipe that feeds gas...
Someone is gonna have to open up that wall
to shift where the pipe penetrates through...
and properly supports all their work.
The cab will need to pulled too.
Old 08-31-2016, 06:03 AM   #5
Rewards Points: 4
Re: Gas pipe adjust
Thanks everyone got a plumber looking at it tonight so hopefully will be sorted
thanks again
jmon likes this.
Old 08-31-2016, 08:58 AM   #6
Rewards Points: 18
Re: Gas pipe adjust
If you are not using this gas line to feed an appliance, it looks to me that you can remove everything beyond the shutoff ( leave the shutoff) and put a threaded plug in the shutoff. Would that accomplish what you are trying to accomplish?
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Can't drain water from water pipe to outside faucet hansim4 Plumbing 19 02-23-2015 02:07 PM
Deep Pipe Clog - Epic Battle Digi Plumbing 37 02-02-2013 11:48 AM
Removing pipe wrap around copper pipe steve3847 Plumbing 1 12-25-2012 02:46 PM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
