Gas Meter Outlet Tee - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-11-2016, 12:49 PM   #1
Rewards Points: 24
Right now the fuel supply side of my meter has a tee, one side of which goes into the house, and the other has a plug screwed in. Is it OK to unscrew the plug on the other side of that tee to add an additional gas line run down the exterior of my house to the the back yard? Or is one side of that tee left available for a reason, like gas company use or something?
jlutsky is offline   Reply With Quote
Old 05-11-2016, 02:46 PM   #2
Rewards Points: 777
Re: Gas Meter Outlet Tee
You could always add a nipple and another tee so the opening is still available.
ct18 is offline   Reply With Quote
The Following User Says Thank You to ct18 For This Useful Post:
jlutsky (05-11-2016)
Old 05-11-2016, 06:22 PM   #3
Most likely it would be ok, but there is a chance that it would not be. Can you post a pic? Or, call your gas supplier and ask them.
hvac benny is offline   Reply With Quote
Old 05-11-2016, 11:01 PM   #4
Rewards Points: 1,932
Just to be safe make sure you shut the gas off before messing with it. All it takes is a static discharge for ignition.
Old 05-17-2016, 07:10 AM   #5
Rewards Points: 1,602
Is the T before the meter or after?
mikegp is offline   Reply With Quote
Weird voltage reading on outlet controlled by switch draftstone Electrical 3 10-01-2015 09:57 AM
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
AFCI and GFCI on same circuit -- 2014 Kitchen Rules Perry401 Electrical 12 10-10-2013 10:09 PM
Meter Main problem. right-sided meter? acerunner Electrical 6 07-23-2011 12:41 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
