Gas Meter Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-25-2016, 08:20 PM   #1
Rewards Points: 310
Gas Meter Help
Hello,
I currently have a gas meter on my house that has a 3/4" outlet port to service the house that currently has a 3/4" pipe coming into the house.
I will be adding additional gas appliances to the house and I calculated a main pipe coming from the meter to the house to be 1 1/4" pipe.
Is the gas company going to have to change out the meter to accept the 1 1/4" pipe?
Thanks,
Pat
patrickpresti is offline   Reply With Quote
Old 01-25-2016, 08:27 PM   #2
Rewards Points: 1,042
Why not ask the gas company?
Canarywood1 is offline   Reply With Quote
Old 01-25-2016, 08:27 PM   #3
Property Mgt/Maint
Rewards Points: 8,184
call your gas co., let them know what additional gas appliances you plan to add. They will tell you if you need to increase the service line
[political signature removed]
Yodaman is offline   Reply With Quote
Old 01-25-2016, 08:33 PM   #4
Rewards Points: 310
I will call the gas company tomorrow. I was just curious if anyone had any experience with this. Thanks!
Insulated Multi-Tap Allowed In Meter Enclosure? walterpassi Electrical 4 09-19-2014 01:56 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 07:24 AM
5/8 water meter with a 1 inch servise line ????? ogoz23 Plumbing 11 02-04-2012 10:35 PM
Is My Electric Meter Correct: Conclusion. fcfcfc Electrical 0 10-03-2010 06:00 PM
How does electricity meter calculate kwh? deerhunter Off Topic 18 09-06-2010 08:26 AM
