Gas Lines - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By Bondo
  • 1 Post By lenaitch
Old 06-14-2017, 08:31 PM   #1
Rewards Points: 324
Gas Lines
Hello...
I purchased an older home that has several gas lines ran under the floor. I am converting the house to all electric, and my intention is to have the gas meter removed.
The previous owner went around showing me where they were. Some were under the new floor he had installed which covered access. He did not know if they were capped. The obvious ones like stove and hot water had access but no type of shutoff I could see;they could be capped easily.
The gas was off when I purchased the house.
Can I leave these lines as they are. Maybe ask the gas company to cap the main entrance line to the house when they pull the meter?
What is the best way to handle them?
slipparee is offline   Reply With Quote
Old 06-15-2017, 05:16 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,324
Re: Gas Lines
Ayuh,.... So long as the gas supply is cut-off from the house, the old lines can be abandoned, cut off, ignored,...
jeffmattero76 likes this.
Old 06-15-2017, 03:03 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 2,112
Re: Gas Lines
I would vote for leaving them capped and in place - it could be an attractive option to a future buyer. I would think the main entrance would be capped when the meter is removed by the utility as a matter of practice.
MTN REMODEL LLC likes this.
lenaitch is offline   Reply With Quote
Running AC/condenser copper lines though the house beachfront71 HVAC 4 05-21-2017 01:33 PM
Are these power lines a concern being next to a tree? miamicuse Electrical 19 02-07-2016 04:46 PM
Transplant tree near underground utility lines? BrandonC_1972 Landscaping & Lawn Care 11 08-26-2012 05:43 PM
Why move/replace heat pump refrigerant lines? EdLank HVAC 1 05-09-2010 05:02 AM
