Gas Line Leak In Attic - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-09-2016, 03:42 PM   #1
Rewards Points: 378
Gas line leak in attic
Yesterday I was up I my attic sealing some hvac ducts and I smelled a little gas.
So this afternoon I put a little leak detection fluid on some parts and bingo, we have a winner.
Anyone have a light??
Looking at the pictures, you think it's just the sealant?
Is this something I can do??
Home was built in 2006.
Thanks.
Gas line leak in attic-image_1455054096570.jpg   Gas line leak in attic-image_1455054111575.jpg   Gas line leak in attic-image_1455054128102.jpg
Alumifab is offline   Reply With Quote
Old 02-09-2016, 03:50 PM   #2
Rewards Points: 4,944
You have turned off the gas, right? Or called the power company?
Nik333 is online now   Reply With Quote
Old 02-09-2016, 03:57 PM   #3
Rewards Points: 3,220
Wow. Thats a leaker for sure. Good thing you found it. Turn gas off for sure.
It looks like something you can do. Take apart redoped_taped threads and tightened down. Check for leaks.
If those threads are rusted out on that regulator, that may have to be replaced as well.
jmon is offline   Reply With Quote
Old 02-09-2016, 04:03 PM   #4
WhatRnsdownhill's Avatar
Rewards Points: 2,220
geez, all that yellow stainless crap..I would go around and check ALL the fitting joints for leaks...since there are no normal unions and the only way to disassemble is to take apart the brass joints that also hold the flexible gas line, you might want to call a licensed plumber...its tricky stuff to work with..
WhatRnsdownhill is offline   Reply With Quote
Old 02-09-2016, 04:22 PM   #5
Rewards Points: 18,790
Well there's a explosion waiting to happen.
And there's a light switch right below to make sure there's going to be a spark.
Running 4, gas appliance off of one 1/2" line, hmm.
Not getting the logic of having two shut off valves on both sides of the regulator and no union to remove it.
No shuts offs to each appliance?
Old 02-09-2016, 04:30 PM   #6
it probably higher pressure so they can run the 1/2 inch line to feed the other 4..thats why the regulator is there...a cheap way of not using proper sized pipe...also looks like many of those gas lines are not supported properly either...
Old 02-09-2016, 04:38 PM   #7
Rewards Points: 378
Yeah, just what I want to do tomorrow, find a license plumber to fix this.
I'm not a fan of my gas setup either, but I just bought the home and obviously there are some things to fix.
Hopefully this is the only leak and it's a quick and easy fix.
Old 02-09-2016, 04:41 PM   #8
yeah..no..you just jinxed yourself by saying that...,,peace of mind I would get someone in to access that mess and see what else could be wrong...
Old 02-09-2016, 04:49 PM   #9
And cut the gas off until they show up.
Just not something to let go.
House go boom, not a pretty site.
Old 02-09-2016, 04:55 PM   #10
Rewards Points: 378
An recommendations for a licensed plumber in the Dallas, tx area?
Old 02-09-2016, 05:06 PM   #11
If it was my house I'd be calling my gas company not a plumber and getting on there 24/7 emergincy # and telling them I have a gas leak.
You would need a plumber that also had a gas licence.
Old 02-09-2016, 05:13 PM   #12
Rewards Points: 378
Atmos gas will turn off the gas, but then tell you to hire a licensed plumber to fix the leak.
They won;t do it unless the leak is outside on 'their side' of the line.
My leak is on my side of the line, so my responsibility.
Even the damn home warranty won't touch it.
So licensed plumber it is.
Also, to get it turned back on I will need to have a city inspector come out and look at the whole set-up and make sure everything is up to code and it all has to be fixed before they will give a green light to turn it back on......
No more gas hot water heater or furnace.
Fun....
Old 02-09-2016, 05:57 PM   #13
Rewards Points: 2,140
Your troubles are a great example of how one problem leads to another. But with this one, whatever it costs to get it fixed right is a small price compared to the alternative. Pat yourself on the back.
Bud
Bud9051 is online now   Reply With Quote
Old 02-09-2016, 06:04 PM   #14
Rewards Points: 378
Thanks, everything will work out. Just 'Murphy's Law' of home ownership, I guess everything will break eventually.....
I am glad that I have been in the attic though working on sealing my flexible ducts. I had a damn lighter and my smoke pen in my bag of many tools and then I noticed the gas smell when I was close to the attic hatch where the gas lines are.....
So yes, I'm happy I found it, but we will see what the final verdict is, of repairs, etc......
If I wasn't a DIYer no telling what could of happened......
Old 02-09-2016, 06:49 PM   #15
Fun....
if you dont want to deal with the town and inspectors, dont call the gas company, just shut it of your self and hire a licensed plumber..
Very slow gas leak is okay KCnorthernCA Plumbing 37 10-02-2016 11:46 AM
How to find a leak in shingled roof without attic ajax911 Roofing/Siding 12 09-08-2014 06:29 PM
Cold Water Line Leak under Sink Greekboy Plumbing 1 06-11-2009 01:46 PM
main line to feed attic qnzkrew HVAC 3 12-28-2007 03:54 PM
