Gas Line To Generator - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-04-2016, 07:28 PM   #16
Rewards Points: 40
Re: Gas line to generator
Originally Posted by supers05 View Post
Actually, it won't matter with 1" pipe. It can handle 374cu.ft/hr or roughly 374,000 btu/hr. That's at 7-14" WC. Up to 1" drop.
So, unless you have a airplane hanger for a house, I think you'll be fine.
Cheers!
Good news, thanks!
brads is offline   Reply With Quote
Old 11-04-2016, 07:51 PM   #17
Rewards Points: 80
Looked over our code. Apparently it's 15" to the top of the pipe. (I've always used 18" since we usually bury 2" pipe.)
We can use type K copper for underground, or either type g or L if it's "externally coated with extruded
polyethylene or PVC resin at the time of manufacture." = Expensive and rare.
Either way, you'll need a tracer wire to run the length of the underground portion. (it's not actually wired to anything just left tied to the pipe above ground at both ends.)
It's highly recommended that you lay down some yellow tape or string above the pipe. 6" or more will do. It helps if you forget where the line is, and the tracer is long corroded. Can be any locally available cheap stuff. Just something recognizable.
You'll need a shutoff valve before it enters the ground, and before the geny.
At 8kW, it won't power much, so I'm guessing you're just running extension cords. If you end up upgrading to something larger, post in the electrical side if you put a transfer switch in.
Cheers!
supers05 is offline   Reply With Quote
The Following User Says Thank You to supers05 For This Useful Post:
brads (11-05-2016)
220v - generator transfer, 3 prong to 4 prong outlet? twaw Electrical 5 11-14-2014 07:12 AM
How to replace your clothes line Fantastic Remodeling 5 08-17-2013 09:17 AM
Champion 7000/9000 Watt Costco Generator wiz561 General DIY Discussions 8 11-24-2012 05:24 PM
Wiring a generator from the garage proteusmd Electrical 20 09-25-2012 03:42 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
