Gas Line To Fire Pit - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-08-2016, 11:29 AM   #1
Rewards Points: 312
Gas line to fire pit
decided to run a gas line to my fire pit (under construction) for future. I obtained a 1" PE gas line from a friend. Here are my questions:
1. can the yellow PE be ran all the way to the center of the fire pit? I would plan on installing black pipe to it later via a Permasert transition fitting.
2. has anyone ever poured concrete over the yellow PE piping?
3. would it be better to run a 2" sleeve from one point to the center of the fire pit and install the yellow PE at a later date when Im ready to have the gas functional?
Please refer to picture in my album. thanks!
KPDMinc is offline   Reply With Quote
Old 11-08-2016, 12:32 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,224
Re: Gas line to fire pit
I would sleeve it and run black pipe near the distribution point.
The thin wall stuff isn't rated for heat.
Old 11-08-2016, 12:53 PM   #3
Rewards Points: 312
Also, does anyone know the rules on bending black gas pipe? I heard it cannot be done according to code, but I need to put a kick in the pipe if I go with the black pipe under the concrete...
Old 11-08-2016, 07:56 PM   #4
Rewards Points: 80
You buy the riser made that way. Complete with the transition from plastic to iron, it comes coated, and bent. All one of piece. Bob's you're uncle.
Cheers!
PS. Random google link. I get mine from a supplier. Watch out for the IPS and CTS size differences. https://www.gastite.com/us/products/underground/risers/
supers05 is offline   Reply With Quote
Old 11-09-2016, 03:52 PM   #5
Rewards Points: 312
Cheers!
does it push on? or need a special heat fuse tool?
Old 11-09-2016, 04:08 PM   #6
Rewards Points: 80
Pushes on like shark bite. Use a pex like cutting tool and ream. That is critical. Ask the company first to make sure. I guess there's alternatives, but that's what I use.
PS. I highly recommend marking the insert depth before installing. It's very hard to tell if it's right once you start without the mark.
Cheers!
Rusting Evaporator Coil: How long do you think, normality, and primary drain line professorj HVAC 1 11-29-2015 08:58 PM
installing refrigerator ice maker line xnera Plumbing 13 07-11-2013 07:11 PM
Gas dryer - installing flexible gas line mspmatt Plumbing 11 12-30-2011 04:32 PM
Help! Glowing spot at bonding screw WillK Electrical 85 12-16-2011 08:22 AM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
