Gas Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2016, 06:42 PM   #1
Rewards Points: 119
gas line
Hi all
My son lives on Long Island
His gas service enters the utility room in the front left hand corner of his house and his kitchen is in the rear right hand corner of his house.
He has an electric stove that he wants to change to gas.
There is no route inside the building through the finished basement.
Is it ok to run the gas line outside along the foundation, buried or on the surface, using 3/4 galvanized pipe.
I can easily punch through the foundation to exit the utility room where all the gas lines are, for his hot water heater and boiler.
Ralph
RH913RH is offline   Reply With Quote
Old 05-09-2016, 07:53 PM   #2
Rewards Points: 3,220
Re: gas line
Every location is different as to what home owners can do in regards to working with gas lines.
Before proceeding with your project, I would contact your local municipality or gas supplier first and ask them directly in regards to the proper material needed, local codes, and whether or not you are allowed to do it. Just a suggestion.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
RH913RH (05-10-2016)
Old 05-09-2016, 09:28 PM   #3
Lord of Slums
Rewards Points: 1,974
Re: gas line
Would not use galvanized. It can be run in the manner in which you say. Gas line is not a diy project.
mj12 is offline   Reply With Quote
The Following User Says Thank You to mj12 For This Useful Post:
Old 05-09-2016, 10:54 PM   #4
Galvanized can't be buried. There's also too many variables and not enough info for anyone here to offer complete advice.
hvac benny is offline   Reply With Quote
The Following User Says Thank You to hvac benny For This Useful Post:
Old 05-10-2016, 04:25 AM   #5
An old Tradesmen
Rewards Points: 9,224
Re: gas line
I doubt it.
You'll need to check with your local code department to see if what you want to do is allowed.
The Following User Says Thank You to beenthere For This Useful Post:
Old 05-10-2016, 05:51 AM   #6
Rewards Points: 10,416
Re: gas line
I had the same problem. I put a couple of holes in the basement ceiling drywall, and then called a pro to run the line. Then patched the holes in the ceiling. Proper final action would be to paint the entire ceiling, but lighting in that area of basement is not perfect and after putting primer on the patches, they were invisible.
SPS-1 is offline   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
Complete blockage of main line mnp13 Plumbing 9 05-29-2012 10:51 AM
Adding a second line to existing septic line Eddietan Plumbing 3 05-10-2012 09:27 AM
Old water supply line a_lost_shadow Plumbing 7 04-19-2012 11:12 PM
Condensate Drain Line Mystery (pan full but no primary clog?) CarrieLP HVAC 21 04-04-2012 11:07 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
