Gas Hot Water Heater In Colorado - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-07-2015, 12:36 PM   #1
Rewards Points: 271
Gas hot water heater in colorado
You guys always have helped me out on Florida stuff. I am helping a landlord in CO. They had some rain and basement got water. The handyman and tenant wet vac'ed this out. GE 40 gallon hot water heater and they cannot get the pilot relit.
The plumber wants $1100 for a new HW heater. The landlord said to have the handyman jack up the HW heater on blocks (re do copper) and clean it out plus replace the burner. Landlord also said there is a pump there for water but that is another story.
Does the burner part sound like it got flooded and maybe mudded? Thanks.
FrankL is offline   Reply With Quote
Old 05-07-2015, 12:59 PM   #2
Was the gas valve at any time underwater?
dangdave is offline   Reply With Quote
The Following User Says Thank You to dangdave For This Useful Post:
FrankL (05-07-2015)
Old 05-07-2015, 01:29 PM   #3
Rewards Points: 271
I am checking.
Old 05-07-2015, 01:29 PM   #4
Rewards Points: 3,468
In the interest of safety, imo, it's a good idea to replace it. When installing the new one, put it up on blocks to help with flooding. Most home owners insurance will cover this. Just a suggestion.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
FrankL (05-07-2015)
Old 05-07-2015, 01:57 PM   #5
Rewards Points: 271
No. The gas valve was not below the water level.
Old 05-07-2015, 04:03 PM   #6
Then you're probably right. Pull the burner and clean it out, blow through the pilot tube and replace the thermocouple just because you can since the burner is out already
FrankL (05-07-2015)
Old 05-07-2015, 04:29 PM   #7
PoleCat's Avatar
Rewards Points: 1,658
My cousins HW heater was completely submerged in a flood. It was fine after it dried out.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
FrankL (05-07-2015)
Old 05-07-2015, 04:48 PM   #8
I've always been told that if a gas valve(wh,furnace) has been submerged it's safeties could be compromised. If I had a submerged valve I would never trust it. Just an opinion
FrankL (05-07-2015)
Old 05-07-2015, 06:35 PM   #9
Rewards Points: 1,942
Frank I would strongly suggest he replace the gas control valve. Any corrosion in that thing will cause a problem.
Not to mention your warranty is now voided.
The Following User Says Thank You to Ghostmaker For This Useful Post:
FrankL (05-07-2015)
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
