Gas Header Leak - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree7Likes
  • 2 Post By chandler48
  • 1 Post By Guap0_
  • 1 Post By Guap0_
  • 3 Post By lenaitch
Old 12-31-2017, 10:38 AM   #1
Rewards Points: 960
Gas header leak
My gas company put a sticker on the door of my building (recently purchased) saying there is a header leak.
I walked around the building and onto all the floors and couldnít smell any leaks. Iím Assuming they mix an odor detecting substance into the gas.
I called the company and they didnít have any insightful information. They told me to call back Tuesday.
Any idea on what I should look for?
jaketrades is offline   Reply With Quote
Old 12-31-2017, 12:52 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,724
Re: Gas header leak
They turned the gas off at the meter, so you wouldn't be smelling anything. You'll probably see a lock on the meter(s) preventing them from being turned on until after an inspection.
joecaption and jaketrades like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
jaketrades (12-31-2017)
Old 12-31-2017, 01:21 PM   #3
Rewards Points: 960
Re: Gas header leak
A friend told me the gas meter probably hasnít been paid in many months. I just bought this property.
Old 12-31-2017, 04:13 PM   #4
Guapo
Rewards Points: 11,950
Re: Gas header leak
The date is 12/22 which was Friday. I don't think it has anything to do with payment. The header will be in the cellar.
jaketrades likes this.
Guap0_ is offline   Reply With Quote
Old 12-31-2017, 04:33 PM   #5
Rewards Points: 960
Re: Gas header leak
Just Spoke with the seller and apparently the gas company was trying to get into the basement to seize the meters. The seller refused to let them in.
Itís a 3 family and my hunch is 2 out of 3 prior tenants owe money on their meter and never paid. The seller was paying on the 3rd meter. So the gas company shut the meter off from the outside and put that sticker on my building to get me to call them.
Old 12-31-2017, 06:43 PM   #6
Guapo
Re: Gas header leak
Then why did they say that it was a leak? Sneaky
Old 12-31-2017, 07:57 PM   #7
Usually Confused
lenaitch's Avatar
Rewards Points: 2,102
Re: Gas header leak
It may be that local laws or company policy prevents a lock-out for arrears either this time or year or below a certain temperature, so they invented a safety cause.
_________________________________________
Bydand
lenaitch is offline   Reply With Quote
Old 01-01-2018, 06:56 AM   #8
Rewards Points: 960
Re: Gas header leak
Yeah Guap - both the seller and gas company are being sneaky. Fortunately there is money in escrow to ensure Iím made whole.
Old 01-01-2018, 10:24 AM   #9
Guapo
Re: Gas header leak
You might want to go to the record room of the local civil court to see what you can find. Some courts have a bank of computers opened to the public & workers there to help.
Roof leak hpmaxim Roofing/Siding 21 01-16-2017 08:49 AM
Possible small gas leak in black iron pipes WillK Plumbing 4 01-17-2012 11:07 PM
Need to determine proper Basement Window Header size- AdamH Building & Construction 1 11-23-2011 02:59 PM
leak in cement tile roof virgo822 Roofing/Siding 2 07-23-2011 05:29 AM
Moving Header Supports Star Building & Construction 3 09-25-2005 12:50 AM
