Garbage Disposal Requirements - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-28-2014, 11:21 PM   #1
Power Gen/RS Engineer
Rewards Points: 566
Hi everyone-
I went to my village's website to check and see what plumbing/mechanical code(s) they follow. According to the Village of Oak Park, Illinois' website, they follow the 2004 Illinois State Plumbing Code with local amendments.
I was curious as to the requirements for garbage disposals and found the following:
Section 890.710 Food Waste Disposal Units
a) Installation. Food waste disposal units shall be trapped separately from any other fixture or compartment, shall be connected directly to the sanitary drainage system, and shall be properly vented. Dishwashers shall not discharge into food waste disposal units. Units may have either automatic or hand-operated water supply control. (See Section 890.1130(a), (b) and (c).)
Of course, I have a few questions that I hope some of you may help clarify.
1. Regarding the text above, particularly "Food waste disposal units shall be trapped separately from any other fixture or compartment, shall be connected directly to the sanitary drainage system, and shall be properly vented."
A. When the code reads "shall be trapped separately from any other fixture or compartment," does this mean that the disposal requires it's own trap that is separate from the sink trap (this disposal is, of course, installed below/part of the kitchen sink)? I know that this may sound like a stupid question but I have rarely seen a disposal in Illinois (near or in the city of Chicago) with a separate trap.
B. Regarding the wording "from any other fixture or compartment," what exactly is a "compartment?" "Fixture" makes sense but could someone cite an example of a "compartment?" Thanks!
2. The code continues on to say "Dishwashers shall not discharge into food waste disposal units." My garbage disposal (like many that I have seen) has a connection for the dishwasher drain. In fact, I thought that it made sense for DW's to drain through the disposal (my disposal has an inlet for this). What this code language seems to suggest (to the contrary however) is that this is not allowed. Am I reading this correctly? If so, how do I properly connect the dishwasher discharge to the DWV system?
I know that these questions might sound dumb and I apologize but I am just trying to understand/learn.
Thanks in advance to all of you professionals that contribute to this site!
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 04-29-2014, 01:04 AM   #2
Rewards Points: 332
Send a message via Yahoo to curtd
Your questions aren't dumb. I also don't understand why after a garbage unit cannot simply emit waste into the sewer line. Did i read post correctly on this point ? ...In fact, when you think about it, i'm a walking garbage disposal unit
curtd is offline   Reply With Quote
Old 04-29-2014, 05:42 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 898
What the rules are saying"
With a 2 bowl (compartment) sink, the bowl without the disposer can not be connected to the disposer. ie: the disposer and the other bowl each must have their own traps.
The dishwasher cannot be connected to the disposer. With a 2 bowl sink, connect the DW to a DW tail piece in the other bowl. In a single bowl sink with a disposer, you need a separate trap for the DW. For a single bowl sink, this is a real PIA.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
MTN REMODEL LLC (04-29-2014)
Old 04-29-2014, 05:43 AM   #4
Retired Moderator
Rewards Points: 7,174
In Illinois every sink must have a separate P-trap---
Do not use the dishwasher drain port on the garbage disposer--you will be hooking the dishwasher drain to the other sink----buy the tail piece adapter at Menards---the Depot does not stock the correct size.
SHR Plumber (04-29-2014)
Old 04-29-2014, 08:24 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 290
And the 2 traps under the sink will share 1 vent- no need to use AAV
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (05-24-2014)
Old 05-01-2014, 09:24 PM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,140
This rule sounds dumb.
Journeyman Plumber
Old 05-01-2014, 10:05 PM   #7
Rewards Points: 1,952
It may sound dumb but it is dumber to do it incorrectly when told how to do it to code.
Dishwasher and garbage disposal problems longislander2 Appliances 7 01-16-2014 10:11 PM
Having electrical trouble with my garbage disposal Bonavita513 Electrical 11 09-25-2012 07:09 AM
switch to garbage disposal question tard01 Electrical 64 03-30-2012 05:19 PM
Old garbage disposal question please help. linuxguy0481 Kitchen & Bath Remodeling 3 07-26-2009 10:03 PM
slow draining garbage disposal lchiu7 Plumbing 3 04-05-2009 03:00 PM
