Galvanized Pipes And Lead - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2016, 11:31 PM   #1
Rewards Points: 208
Galvanized Pipes and Lead
In light of the lead in water issue in Flint, MI because of galvanized pipes...what about the millions of homes in this country that still have galvanized water pipes? Are these homes at risk too for lead poisoning?
Scully is offline   Reply With Quote
Old 01-22-2016, 12:00 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 18,160
Depends on the type of galv pipe you have. If it's the typical threaded type....lead is not an issue
But if you have Galv pipe, it's only a matter of time before it rusts....replacement should be in your future plans
ddawg16 is online now   Reply With Quote
Old 01-22-2016, 12:06 AM   #3
Rewards Points: 82
I don't think so, in our area we are stilling using a galvanize water pipe until now. This type of pipe doesn't harm us. PVC pipes it could be.
cmorales is offline   Reply With Quote
Old 01-22-2016, 04:39 AM   #4
Retired Moderator
Rewards Points: 7,174
I believe the lead came from a river polluted with industrial waste--not the pipe that carried it to the homes.
JERRYMAC (01-22-2016)
Old 01-22-2016, 08:03 AM   #5
Civil Engineer
Rewards Points: 5,246
Galvanized pipe is zinc coated steel. There is generally no lead in a galvanized pipe. For more information on this topic, see https://www.dcwater.com/waterquality/plumbing/faq.cfm.
Problems arise because over time, the zinc coating on the pipes breaks down, and the steel rusts. This occurs more rapidly in corrosive water, which may be due to acidity of the water, or minerals in the water. Once the pipe starts to break down, various issues arise such as loss of flow, reduced pressure, and formation of internal clogs that can collect lead from incoming city water mains (yes, many cities still have lead pipes for water delivery).
In the case of Flint, the city changed water supply from Lake Huron to the Flint River in an effort to save money. The Flint River has corrosive water, primarily due to iron content, and as a result the city water pipes, some of which are apparently made of lead, started to leach lead into the water system. I would not be surprised to find out that many of the houses in Flint have copper water supply pipe that use 50-50 lead/tin solder joints, and the joints may have leached lead into the house water, contributing to the problem.
You can read a decent summary of the issues in Flint here http://www.cnn.com/2016/01/11/health...lint-michigan/.
I had to replace some galvanized pipe in my house, along with all the copper pipe, about 15 years ago due to my acidic well water. The options were to treat the water to make it less acidic, or replace the pipe with PEX, which is inert to acidic water. The pipes were all deteriorated (pin hole leaks, corrosion) so I simply replaced all the pipe. But I suspect that prior to my replacement, I was probably leaching lead from the solder joints. Modern copper solder is 95% tin, 5% antimony. I have no idea if antimony is leached into water, and I don't know if it is toxic. Similarly I don't know if the tin is OK. Seems we find out about problems long after the fact.
The Following 3 Users Say Thank You to Daniel Holzman For This Useful Post:
JERRYMAC (01-22-2016), oh'mike (01-22-2016), Scully (01-23-2016)
Old 01-22-2016, 06:54 PM   #6
Rewards Points: 1,414
Some municipalities also don't replace old pipes until the old pipes go, or occasionally if they don't have enough supply, for example. I suspect there are a LOT of underground lead supply pipes still kicking around in old cities and towns.
Tom738 is offline   Reply With Quote
Old 01-22-2016, 09:23 PM   #7
Super Moderator
joed's Avatar
Rewards Points: 31,586
I think the lead came from the pipes because the chemicals in the river water dissolved them better than the Detroit water.
The Following User Says Thank You to joed For This Useful Post:
oh'mike (01-23-2016)
Old 01-23-2016, 01:51 AM   #8
Rewards Points: 208
In referencing these lead/tin jointed copper pipes, in which era of homes built would you find these kind of pipes? I always thought that copper pipes were just copper and nothing else...
Old 01-23-2016, 06:53 AM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,034
Ayuh,... The pipes are copper, the solder used to join 'em had lead in it, til the '80s or so,....
The Following User Says Thank You to Bondo For This Useful Post:
Old 01-23-2016, 08:28 AM   #10
Rewards Points: 5,434
And do we know what percent zinc / lead the alloy was at the time of galvanization. Without strict controls we can be assured if lead was less expensive than zinc then more lead was added.
Old 01-23-2016, 09:07 AM   #11
Civil Engineer
Copper pipes commonly use solder to join pieces together. As noted by others, up until the 1980's the solder was a 50/50 mix of tin and lead. I still have some old 50/50 solder in my basement. Eventually the solder transitioned to lead free, which is 95 percent tin, 5 percent antimony, which is the current copper pipe solder sold.
Galvanized pipe is typically joined by threading, there is no solder used, so if you have galvanized pipe in your house, you will not leach lead out. You will definitely leach zinc out, since the steel pipe is coated with zinc (the galvanization metal).
The Flint River water did not test positive for lead, that was never the issue. The issue is that the Flint River water is more corrosive to pipes than the Lake Huron water that Flint used to purchase from Detroit. The additional corrosivity of the Flint River water leached lead out of City of Flint lead water supply pipes, and perhaps leached lead out of the solder joints in houses that used copper pipe for water supply (probably most of the houses in Flint).
As a note, many municipalities have lead water supply pipes, and continue to use them. I worked on several Boston water supply project, and Boston still has some in use lead pipes, and some wooden ones as well. It is very expensive to replace water pipes, and of course infrastructure is chronically underfunded, so municipalities try to stretch the life of pipes to the end.
Old 01-23-2016, 01:18 PM   #12
Rewards Points: 1,852
That was a smart decision to save money on the part of Flint....
Old 01-23-2016, 01:34 PM   #13
Bondo's Avatar
Ayuh,.... 'n mighty friendly of neighborin' Detroit to tryin' Over-charge Flint for the water they were usin',....
Flint really had no choice, other than go broke with Detroit, or use they're backup system til the new pipeline is built,....
Old 01-23-2016, 04:09 PM   #14
Rewards Points: 208
well, that's alarming to hear, that children could be ingesting lead. i guess that's the economic reality of our municipal funding.
Replacing Some Galvanized Pipe epsilono Plumbing 6 12-03-2015 07:53 AM
ok ric , lets see if you know ltd Painting 5 09-07-2012 10:36 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Hot water pipes (closed system) vibrate very loudly. Peety HVAC 8 02-07-2010 09:53 AM
What are the extra lead pipes for??? crazytank7 Plumbing 9 12-06-2008 01:58 PM
