Frozen Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2016, 08:07 PM   #1
Rewards Points: 109
Frozen pipe
so I had a frozen shower today- the lines are cvpvc, I was able to put a space heater in the room and thawed them out with no damage-- LUCKY I know. 10*and windy
The supply lines come out of the house to the addition and t off for the sinks and toilet and continue to the shower- only the shower froze so I think it is right at the shower bay where the issue is.
Interior wall 2' off the exterior wall, slab on grade. I can't remember if I insulated the wall bay with the pipes and it is a slab on grade with a hole into the dirt for the tub trap....
I am thinking about cutting a hole in the wall and insulating the lines right there and stuffing the wall with insulation.....
Thoughts?
gwilkrrs is offline   Reply With Quote
Old 01-19-2016, 08:26 PM   #2
Rewards Points: 582
Thoughts?
you can see what you need to do...insulation is the best bet...sounds like a plan
The Following User Says Thank You to ben's plumbing For This Useful Post:
gwilkrrs (01-19-2016)
Old 01-19-2016, 09:08 PM   #3
Rewards Points: 1,848
Insulating the pipes will do no good. Cut a register cover in to allow heat into the area.
That may work.
You can insulate pipe but if you think about it. Lets say I insulate two pipes stick them in a freezer will they freeze?
Yes they will you need a heat source to keep temps above freezing.
Old 01-19-2016, 09:18 PM   #4
Rewards Points: 10,370
That's not a very good description of the geometry of your situation, but anyways, you need insulation between the pipe and the outdoors, and no insulation between the pipe and the indoors.
SPS-1 is offline   Reply With Quote
Old 01-19-2016, 10:18 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 31,580
You don't want to insulate the lines. You want to leave them exposed to the inside(warm side) of the wall. Only insulate on the outside(cold side) of the wall. If you have to, build a box around them open towards the inside wall and insulate around that.
Old 01-19-2016, 11:09 PM   #6
Rewards Points: 582
if you stop the leakage of cold air on the pipes ...by stuffing the bay and insulating the line ..it should be fine...don't let this become a major project as some my think...
Old 01-20-2016, 04:40 AM   #7
Rewards Points: 5,424
He!! yes an outdoor shower is gonna freeze.
Why you people wasting your time on this 20 questions game. What a hoot.
SeniorSitizen is offline   Reply With Quote
Continuous Current on Water Pipe terps530 Electrical 263 04-11-2015 12:08 AM
Sewer gas smell in house - frozen vent pipe? secutanudu Plumbing 8 02-15-2015 09:31 AM
Frozen Pipe in Back Bathroom Addition joetab24 Plumbing 11 01-14-2015 07:22 PM
Hot water pipe frozen d_heath Plumbing 1 02-10-2013 03:01 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
