Front Loading Laundry Washing Machine - Flood Rim? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-12-2016, 10:16 AM   #1
Rewards Points: 42
It's my understanding that I can't run a dry vent horizontal until it's at least 6" above the flood rim of the fixture. It's also my understanding that the standpipe for a washing machine must extend at least 24" above the trap weir and must terminate above the flood rim.
Most examples I find are associated with a top loading washing machine and basically specify that the top of the washing machine or it's drum is the flood rim. What exactly would be the flood rim on a front loading washing machine? I assume it'd be the bottom height of the front loading door?
bajafx4 is offline   Reply With Quote
Old 02-12-2016, 10:39 AM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
the extension of the standpipe is more so suds dont flow out the top, the 6 inch above flood line has nothing to do with the machine, its the plumbing in the walls, 6 inches above the stand pipe or a sink... whatever is the highest fixture drain..
WhatRnsdownhill is offline   Reply With Quote
Old 02-13-2016, 07:12 AM   #3
Rewards Points: 1,852
Flood level rim is defined as the point where waste water will spill over onto the floor. So your answer is correct.
Strainer in washing machine discharge line? bwendholt Plumbing 7 12-04-2011 06:01 AM
Plumbing a Washing Machine Drain MikeWood Plumbing 2 01-21-2010 07:10 PM
LG Front loader washing machine repair sharz Appliances 1 04-19-2008 10:30 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 12:26 PM
