Foundation Wall Pipe - Dark Spot - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By joed
Old 08-09-2016, 10:37 AM   #1
Rewards Points: 6
foundation wall pipe - dark spot
We recently had the piping going through our foundation replaced a few weeks ago, and ever since then i noticed there has been a dark spot around the hole in our foundation wall. I don't think its moisture because we haven't had rain in a while and we had a dehumidifier in that room for over a week. Can anyone tell me if this is normal? I have attached a picture
mikeivb is offline   Reply With Quote
Old 08-09-2016, 12:30 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,930
Re: foundation wall pipe - dark spot
It is probably normal. Hydraulic cement, which they probably used to plug the hole, is often darker colour than regular concrete.
If it feels dry you are fine.
lenaitch likes this.
surface drainage above a retaining wall Benjamin5 Landscaping & Lawn Care 4 09-26-2015 02:44 PM
Joining thin wall abs pipe to standard abs pipe Homerepairguy Plumbing 3 03-01-2015 11:39 PM
Added complications for a 12' high foundation wall AlexHouse Concrete, Stone & Masonry 2 01-28-2015 01:28 PM
injecting foam for freezing pipe in wall gunner666 Insulation 7 01-13-2015 02:26 AM
Cutting into foundation wall to install entry door. notenoughtime Building & Construction 7 08-19-2009 02:13 PM
