Forgot To Install Plastic Washer For My Toilet You Think It Matters? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By MTN REMODEL LLC
Old 12-01-2016, 12:55 AM   #1
Rewards Points: 178
forgot to install plastic washer for my toilet you think it matters?
Hey guys, first time installing a toilet and just realized after installation i forgot to install 2 plastic washers for the toilet located sitting on top of the toilet base. It a American Standard mainstream toilet, apparently the instruction was to put a plastic washer first which touches the toilet than a metal washer on top of the plastic than the nut to tighten the toilet down shown in diagram number 4. you think I should be worried? can anything go wrong if i unscrew the nuts and remove the metal washers and put in the plastic first and reinstall?
bklynsoulja is offline   Reply With Quote
Old 12-01-2016, 03:57 AM   #2
JUSTA MEMBER
Rewards Points: 3,260
Re: forgot to install plastic washer for my toilet you think it matters?
Those plastic washers are there to prevent the metal washers from "STRESS CRACKING" the porcelain.
No it will not cause any harm to gently remove the metal, and install the plastic, then the metal, just remember to tighten it all evenly, do not torque it super tight.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
bklynsoulja (12-01-2016)
Old 12-01-2016, 05:02 AM   #3
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,682
The top ones also hold the caps in place.
If you're talking about the retainer washers below, no you don't need those. They are just a convenience to hold the bolts in place.
123pugsy is offline   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
Old 12-01-2016, 08:07 AM   #4
Rewards Points: 1,054
Replace one side at a time and try not to rock the toilet. Do not overtighten. Make sure your toilet is level and that you use grout to support it. Leave a 1" gap at the back so if the toilet leaks, you will see it as soon as it happens.
clarenceboddick is offline   Reply With Quote
The Following User Says Thank You to clarenceboddick For This Useful Post:
Old 12-01-2016, 08:15 PM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,756
It's fine.... just don't sit on it....
de-nagorg likes this.
MTN REMODEL LLC is offline   Reply With Quote
Plastic toilet bolts? Thurman Plumbing 12 07-09-2016 09:29 AM
Do I need seal junction between old toilet flange and plastic extension ring? sukhenkoi Kitchen & Bath Remodeling 5 06-29-2011 07:52 PM
How do you install a toilet over Laminate? yohan Flooring 6 07-22-2008 07:07 AM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
Commerical Building - Install Drain under toilet? TransTech Plumbing 4 02-25-2008 10:08 PM
