Food Grade Surfactant? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-22-2015, 02:25 PM   #1
Rewards Points: 47
food grade surfactant?
I use a permanent sediment filter (made by Water Source) up stream of my water softener's 20" cartridge filter canister to extend the life of the replaceable cartridge filters. This particular sediment filter has a plastic bowl with a removable 200 micron screen inside of it.
There is a valve at the base where one can blow down the trapped sediment that lies in the bottom, along with whatever larger pieces are up against the screen (this is a deep well water system). I blow the unit down every day and have to remove the screen every 2 weeks to remove the smaller pieces of sediment and iron that have become embedded in the screen. This is really very simple to do and takes
almost no time at all.
My issue is with the rust that collects on the interior of the bowl. I have been using 0000 (very fine) steel wool to remove the rust (which makes it difficult to see through the bowl to check the amount of blockage on the screen) about once every two months (the iron concentration in our water isn't really that high). This task is a hassle because the bowl is 6" deep and one cannot reach the bottom with fingers alone. Over time, I can tell that the bowl is beginning to become slightly foggy due to the light scratching caused by using the steel wool. I have not tried using products like CLR because I do not know how they would affect the plastic, and also because I'm not so sure that would be considered safe in a
drinking water system.
Is there some kind of a food grade surfactant that could be used to coat the inside of the bowl that would prevent the rust from adhering to it? If you have any other suggestions, they would be most welcome. If I could obtain a glass bowl, I'd go that route, but there is nothing available.
Thanks for your time and consideration. Rob
killermrob83 is offline   Reply With Quote
Old 01-22-2015, 04:55 PM   #2
Rewards Points: 6,598
Try paraffin on a test area.
Code concerning porch joists near grade Jim McC Building & Construction 10 06-17-2013 04:55 PM
Exterior wiring above and below grade for hot tub in Pennsylvania pkcrouse Electrical 0 05-31-2012 10:49 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 08:59 AM
