Flushometer And Water Hammer - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-19-2017, 10:44 AM   #1
Rewards Points: 4
flushometer and water hammer
i replaced my gem flushometer with a gem 2 (piston). i set the stop as low as i can so it still flushes and i still get some water hammer. if i switch to a diaphram type would that lessen the water hammer? my thought is the diaphram probably closes slower than the piston. an i correct?
i07nyc is offline   Reply With Quote
Old 11-19-2017, 06:38 PM   #2
Rewards Points: 3,418
Re: flushometer and water hammer
Yes, Imo, I agree with ur thought process. Switching it out may help.
What you can try first is just backing off the supply feeding toilet a little, see if that helps.
This helped my problem with a water hammer on my new washing machine. The new machine had those quick piston like shutoffs as well. Old machine was fine, but newer one had quick piston shutoffs which caused a really bad hammering. Just a suggestion.
jmon is offline   Reply With Quote
Old 11-20-2017, 06:02 AM   #3
Rewards Points: 4
I have my supply turned as low as it will go and still flush. The pipes are not earth shatteringly banging. Just a little bump.
Water level low in toilet bowl in flushometer toilet. falconi Plumbing 2 07-05-2017 03:38 PM
expansion tank with flushometer (1/2" to 1 !/4") rw4smithers Plumbing 4 04-14-2016 12:20 PM
Sloan flushometer valve won't shut off BradG Plumbing 3 01-24-2008 09:04 AM
