Flushometer Selection? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-05-2015, 09:27 AM   #1
Rewards Points: 290
Flushometer selection?
Sorry for another urinal post, but I'm looking to pull the trigger today on a flushometer for a 0.5gpf washout urinal.
I never realized before that there were different flush types for urinal's (washout, siphon jet, blowout, etc). The flush valve I'm looking at doesn't mention anything (other than being 0.5gpf).
So does the difference between urinal's just come from the porceline fixture itself? Or do the flush valves come designed for different use?
gizzygone is offline   Reply With Quote
Old 12-05-2015, 11:15 AM   #2
Rewards Points: 1,866
The urinal you purchase should specify the Gallon flush it needs in it's specifications.
You get the porcelain and buy the valve they recommend for the flush based on the porcelain GPF
Old 12-05-2015, 12:05 PM   #3
Rewards Points: 290
Okay, so there aren't any special "blowout" flush valves? As long as the GPF matches I'll be fine?
I'm looking to match the Sloan 995-0.5 to the Toto ut104ev
Old 12-05-2015, 05:11 PM   #4
The toto recommends specific flush valve manufacture. Safer to stick to that.
http://www.specsserver.com/CACHE/frifhsfvaogp.pdf
Old 12-06-2015, 09:16 AM   #5
Rewards Points: 290
Well that stinks...
Old 12-06-2015, 11:53 AM   #6
Rewards Points: 290
What do you think the toto does special compared to the Sloan? Different flow rate?
Flushometer bowl with side attachment 20s toilet Plumbing 3 01-24-2012 09:37 PM
Flushometer and Top Spud Toilet tfcdont Plumbing 1 08-14-2011 09:15 AM
Aura Sheen selection and color selection rockisland Painting 0 03-23-2010 11:09 AM
cordless tools, largest selection for single battery? rig Tools 9 12-18-2009 10:37 PM
Flushometer valve Gabriel24 Plumbing 2 03-05-2009 10:05 AM
