Flushmate Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2015, 04:54 PM   #1
Rewards Points: 26
Flushmate question
Hey all, a quickie question. Last year about this time I gutted the master bath and installed all new Kohler stuff. I took the existing toilet with flush mate and used that one in the 1/2 bath ditching the one that was in there. Since that flush mate is not not being used for a few days at a time it seems to lose it's charge. I never had a problem when it was used several times a day. When this happens if I flush it about ten times it charges up again and works perfectly.
I'm guessing there is a small air leak someplace but could find non using the soap bubbles I use for gas piping. Or maybe it's normal if unused for a few days?
Thanks.
Threecats is offline   Reply With Quote
Old 01-01-2015, 05:09 PM   #2
Rewards Points: 3,430
I agree with you, small leak somewhere. Sounds like a worn o-ring/cartdrige. Idk, just guessing at this point.
Is it a push-button or handle flush? Post a picture of it with cover off if you can. Thanks.
Click post reply, type a sentence, scroll down to manage attachments, upload/post pics from there, click submit reply. You can also click preview post if you want to see it before posting.
jmon is online now   Reply With Quote
Old 01-01-2015, 05:43 PM   #3
Rewards Points: 26
It's this one here. I think there is a rebuild kit if it starts acting up worse I may look into it or just go with a new unit. The reason I like it beside the obvious that you can flush a whole chicken is that the toilet it's in is fairly short. It's tiny room and most toilets now have a longer footprint that would bring the front end almost into the doorway. (pocket door)
https://www.flushmate.com/discontinued/
The Following User Says Thank You to Threecats For This Useful Post:
jmon (01-01-2015)
Old 01-01-2015, 06:01 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 248
You might want to get your model # and do some research. One of those models was recalled.
http://www.cpsc.gov/en/Recalls/2014/...ushing-System/
Old 01-01-2015, 06:05 PM   #5
Rewards Points: 26
Thanks. This was not one of the recalled.
TheEplumber (01-01-2015)
Old 01-01-2015, 06:50 PM   #6
Super Moderator
joed's Avatar
Rewards Points: 31,932
We had them at work. The only fix was to replace them. The ones we had that leaked were the 501 tanks with the steel ends. All the new ones a complete plastic.
We also a bunch of the recalled ones. They will send you a repair kit for it. Just phone them with the serial numbers off the tanks. The kit includes a pressure regulator that gets installed on the inlet and band that fits around the tank to keep it from blowing in half. The first one took 15-20 minutes to install. After figuring out what needed to be done the rest took about 5-10 minutes. We had to do about 15 tanks total.
The leaking tanks with steel ends.
The Following User Says Thank You to joed For This Useful Post:
jmon (01-01-2015)
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
