Fluidmaster 3" Flapper Seal - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-01-2016, 07:10 PM   #1
Rewards Points: 770
Fluidmaster 3" flapper seal
Does anyone sell the seal "alone" to fit a Fluidmaster 5403 or 3" flapper valve?
wptski is offline   Reply With Quote
Old 09-01-2016, 08:20 PM   #2
Rewards Points: 3,216
Re: Fluidmaster 3" flapper seal
Check amazon.com or a local plumbing supply store. you can buy just the seal for $2.43.
https://www.amazon.com/Fluidmaster-5.../dp/B002C1AVV8
jmon is online now   Reply With Quote
Old 09-02-2016, 07:25 AM   #3
Rewards Points: 770
Thanks! That's the part I found once and couldn't find it later on.
Not sure about local plumbing supply as I asked about a globe valve gasket and was told they don't sell parts just the whole valve.
The Following User Says Thank You to wptski For This Useful Post:
jmon (09-02-2016)
Old 09-04-2016, 12:31 PM   #4
Rewards Points: 770
Funny, that seal is an add-on item only from Amazon so I ordered one on eBay for a little more. It came today delivered by USPS in a Amazon packet just like Amazon Two Day Prime. Crazy....
I had a Fluidmaster 3" kit so I actually took the flapper valve from it to fix the toilet. The Keeney seal is different, it's thicker, larger OD and there is a ridge near the ID that's not on the Fluidmaster OEM seal.
If you face the ridge toward the flapper's seat it will go on, a bit more taught because the ridge stops it from going in the slot anymore but feels like it's laying flat and should work.
If Keeney sells the seal only for theirs why doesn't Fluidmaster?
jmon (09-04-2016)
New Sink Drain Seal caveeagle Plumbing 6 02-10-2014 08:22 PM
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 01:56 AM
How to apply caulk to seal water pipe through basement wall goshenplumber General DIY Discussions 4 07-08-2013 08:40 PM
Garage door seal segal Windows and Doors 4 05-25-2013 07:47 AM
Anchor Seal Leaching on IPE rocketdoctor Building & Construction 5 09-07-2010 09:46 AM
