Flow Rate Restrictor On Shower Panel - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 1 Post By RRH
  • 1 Post By akuhn235
  • 1 Post By hkstroud
Old 10-12-2017, 09:25 PM   #1
Rewards Points: 960
Flow rate restrictor on shower panel
I have a vigo rain shower panel. The pressure isn’t good in the current setting. I can replace the flow rate restrictor - going from 2.0 Gpm to 2.5 gpm. Or I can have no flow rate restrictor in there.
Vigo tech support suggested having no restrictor in there could damage the shower panel hardware.
Thoughts? Is there an after market restrictor that runs higher than 2.5gpm?
jaketrades is offline   Reply With Quote
Old 10-16-2017, 05:12 PM   #2
Rewards Points: 960
Re: Flow rate restrictor on shower panel
Bump. Any opinions?
Old 10-16-2017, 05:33 PM   #3
RRH
Rewards Points: 1,472
I think you talked to someone that is not knowleageable.
I cant think of anything that would be made so weak that it would be a problem. Did you ask him what hardware it could damage. Bet he does not know.
I say just remove it. I never thought flow restrictors were a good idea. If I want less pressure I will just turn down the valve.
Most just install because of government regulations. And then people like me just remove them before we install.
jaketrades likes this.
RRH is online now   Reply With Quote
The Following User Says Thank You to RRH For This Useful Post:
jaketrades (10-16-2017)
Old 10-16-2017, 06:12 PM   #4
Rewards Points: 960
It was the tech support guy at Vigo. He said it “may” damage the hardware.
Old 10-16-2017, 07:22 PM   #5
Rewards Points: 126
the pressure observed by the system without a flow restrictor won't be all that much greater than the pressure observed with one. If these are tested to typical standards ASME 112.18.1, they are tested at 125psi. Your plumbing system typically doesn't see anything near that, as I think most homes are around 30-70psi, depending on your elevation in relation to your water source. I'd take out the flow restrictor and see how you like it. Is there some other kind of filter in the unit before/after the flow restrictor?
akuhn235 is offline   Reply With Quote
The Following User Says Thank You to akuhn235 For This Useful Post:
jaketrades (10-17-2017)
Old 10-17-2017, 12:16 AM   #6
hkstroud's Avatar
Rewards Points: 6,694
A flow rate restrictor restricts the flow or volume not the pressure.
Remove it.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
Old 10-17-2017, 07:13 AM   #7
RRH
But also there is the problem with a larger shower head like you have. Or when people try to install some of these that have a few nozzles.
I myself like a lot of pressure when I take a shower. Most house dont really have enough pressure to feed these types without lowering the pressure because of larger or more heads.
So just not for me.
Old 10-17-2017, 02:15 PM   #8
Rewards Points: 1,928
How large is your drain? Sounds like vigo voids warranty.
Vigo is not responsible for any alterations and the affects
that may come with altering the product, post sale and highly advises that
the client only install product that meets the needs of their local plumbing
code.
Old 10-17-2017, 04:22 PM   #9
RRH
code.
What does the drain have to do with anything?
This does not change the drain. Which is sized to take the full volume that the house can supply.
Old 10-17-2017, 04:55 PM   #10
Because if you increase the GPM output of your shower heads your drain must be sized to take the water. Pipes can only do so much. It isn't magic its physics.
Old 10-17-2017, 05:59 PM   #11
Rewards Points: 960
2” drain. My curb is 6” tall. Not really worried about flooding my bathroom.
Old 10-17-2017, 06:19 PM   #12
RRH
No. The drain is already sized for the max flow the whole house can provide. Even if every faucet was on and ran to the shower drain. Even oversized at that.
You are saying if you put in a low flow showerhead. And then later put in a full flow or no shower head. That you would increase the drain size. Makes no sense.
That is why you will never see a house faucet or showerhead of any type that tells you to check your drain size before you install.
The city water meter will only allow so much flow.
No flow from Delta 1700 shower valve after cartridge replacement billyjoe Plumbing 11 04-24-2016 02:42 PM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
Replacing shower faucet without access panel DDDIVA52 Plumbing 4 03-16-2012 07:44 PM
Avante shower cartridge replaced, now water flow is low? tmac4 Plumbing 4 02-19-2010 02:45 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
