Flotec Utility Pump Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2016, 09:41 AM   #1
Rewards Points: 115
flotec utility pump replacement
Hi all. I was trying to find a replacement flotec pump 1/3 hp for a laundry discharge basin but I am having trouble finding the right one. I see a lot of utitech pumps but I am not sure of their quality. Anyone familiar with these pumps? I'm thinking I may have to go to a plumbing supply to get a quality pump. Any thoughts on a good pump would be appreciated. Thanks
pokey is offline   Reply With Quote
Old 01-03-2016, 01:50 PM   #2
Rewards Points: 352
I always prefer the plumbing supply warehouses over big box stores. The counter guys have a lot of knowledge if you don't act like a d***.
plumberinlaw is offline   Reply With Quote
Old 01-03-2016, 02:37 PM   #3
griz's Avatar
Rewards Points: 572
http://www.flotecpump.com/
griz is offline   Reply With Quote
Old 01-03-2016, 02:44 PM   #4
Rewards Points: 127
The pump selection at the big box stores is usually pretty limited and miserable
jimn01 is offline   Reply With Quote
Old 01-03-2016, 02:56 PM   #5
Rewards Points: 8,303
Agree and if your washer does not have a lint filter, consider a sewer pump which can pass the solids a lot better.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is online now   Reply With Quote
Old 01-03-2016, 06:00 PM   #6
Rewards Points: 114
Flo tech pumps just feel cheap. I like these for laundry rooms. Usually I dump the machine into a sink and drain the sink into the pump. It's not s sewer ejector pump so if you're not using anything to stop the lint you need to clean the inlet filter probably once a month. Four screws and five minutes to do.
http://www.amazon.com/Little-Giant-W.../dp/B0018LD5T8
2x_Tom is offline   Reply With Quote
Old 01-03-2016, 06:35 PM   #7
Rewards Points: 115
thanks all for the info.i will check with the local plumbing supply. sounds like the way to go. thanks again
Rainwater in Ejector Pump Joyce58 Plumbing 12 12-16-2015 04:39 PM
Water Utility Pump stopped working MattBK Plumbing 8 08-28-2015 09:27 AM
Heat pump fan motor replacement Mark Tat HVAC 11 01-29-2012 04:40 PM
utility sink pump furiousstyles Plumbing 4 11-06-2009 03:52 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
