Floor Drain Trap Venting? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-24-2015, 06:56 AM   #1
Rewards Points: 51
Question
floor drain trap venting?
Hi,
Just pouring slab for a garage and setting up two floor drains. They are all-in one units with traps and back water valve built into drains. They will run to just outside my slab and dump into a below grade pit or french drain. Do I also need to run a vent line for trap venting?
deepstuff is offline   Reply With Quote
Old 11-24-2015, 08:03 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,342
For the floor drain? The air is already there.
Old 11-24-2015, 08:15 AM   #3
Rewards Points: 18,772
And there's no sewer gas to vent.
Old 11-24-2015, 06:07 PM   #4
Rewards Points: 1,854
A floor drain is just a bigger trap guys. Yes they do need to be vented. In his case they do not since they do not tie into the poop sewer.
Ridge Cap Venting Issues - Poor Ventilation?? askeyb Roofing/Siding 16 03-29-2016 04:05 PM
S trap? Venting question ccbs1 Plumbing 35 01-27-2015 04:32 PM
HELP - Broken Sink Trap Fitting NIGHTMARE! Steve Sr Plumbing 17 03-10-2013 05:45 PM
PVC trap adapter on galvanized trap? dougan Plumbing 2 10-05-2012 06:16 AM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 07:59 PM
