Flexible B Vent Vs Code (on Wtr Htr) - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Ghostmaker
Old 08-30-2016, 11:35 AM   #1
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,650
Flexible B Vent vs Code (on wtr htr)
Using flex made this job soooooo much simpler.
Two years ago while doing some other work I had the inspector in.
Nice guy. Very helpful btw...
He said that the Flex was NOT allowed here.
(City of Winston Salem in Forsyth County)
I really don't want to have to buy all new stuff and re-do this.
Let alone having to cut up 4 ells and have all those extra joints...
Q: How can I protest or whatever?
or maybe the code has changed since then?
Old 08-30-2016, 05:05 PM   #2
Rewards Points: 1,852
Re: Flexible B Vent vs Code (on wtr htr)
se B-Flex
anywhere B-Vent is
required, except where pipe
penetrates the structure; walls,
floors, ceilings, roof
Any of these areas penetrated use rigid.
jeffmattero76 likes this.
Old 08-30-2016, 05:45 PM   #3
MarginallyQualified
Originally Posted by Ghostmaker View Post
except where pipe penetrates the structure; walls,
I think this is what is going on.
The WH is in the utility room...
I hard piped through the wall (with thimble)
into another tempered area...
THEN I started the flex to get around a build out on that side.
When I asked about the GWB chase I was thinking about...
he might have assumed the flex went thru the wall. (it doesnn't).
Thanks.
Basement Toilet Venting Question scottgibson Plumbing 17 02-21-2010 10:34 AM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
cold air return vent height. is there code? DangerMouse Building & Construction 4 10-07-2008 01:53 PM
Flexible gas line and dryer vent? kcrossley2 Plumbing 5 05-05-2008 11:31 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
