Fleck 5600 Piston Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-10-2015, 01:44 PM   #16
Rewards Points: 40
Thanks for the follow up. I appreciate all your help.
cap33905 is offline   Reply With Quote
Old 05-04-2015, 04:29 PM   #17
Rewards Points: 40
Situation Update:
I had a filter installed, and sand is not my problem. Local company says that it could be the sulfur eating the piston. I drilled five inch holes around the top of the aerator tank to let more of the gas escape, and I thought fixed things. It did not. Over the weekend I noticed a large wet spot in the yard, and found that the softener was just dumping water down the drain. Local company suggested putting a spray bar inside the aerator with a basket and chlorine tablet. When the tank fills, the water sprays over the tablet. Will this remove the sulfur? Also after my wife did a load of laundry there was a bunch of tan sand like material in the machine. I think it is resin from the softener. How does this happen, and does the softener need to be replaced? I do believe it is time to replace the control valve, I rebuilt it and it still does not cycle properly.
Hot water problems - not sure what's causing it ngk Plumbing 6 03-29-2013 06:42 PM
Keep 13 year old Kinetico or buy new Fleck 5600? MateoZ Plumbing 2 07-15-2012 08:45 AM
Fleck 5600 - How much resin do I need? jpp977 Plumbing 1 11-13-2011 12:09 PM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
