Fitting A New Toilet In First Floor, What Do I Need - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2015, 06:07 PM   #1
Rewards Points: 294
Fitting a new toilet in first floor, what do I need
I'm going to fit a new toilet in ex-laundry room (none there before), I want to run the drain into the main basement cast iron vertical drain. What do I need to do it?
I have looked all over for an example but there doesn't seem to be anything out there.
Mikeron is offline   Reply With Quote
Old 01-21-2015, 06:18 PM   #2
Rewards Points: 1,948
A layout of your proposed bath. The state you reside in so we know what plumbing code to use. Some measurements of space and how the joist lie below the floor.
Also where a 3 inch or larger drain exist to get to.
Old 01-21-2015, 06:57 PM   #3
Rewards Points: 294
New York and the iron drain is 4 inches
Old 01-21-2015, 07:20 PM   #4
Rewards Points: 6,518
Google sanitary T and Wye. Your code may allow either to connect to your 4" vertical.
SeniorSitizen is offline   Reply With Quote
Can high water pressure cause a toilet to run? sirienne Plumbing 6 01-13-2013 07:58 PM
On-going toilet issue(s) bknifefight Plumbing 4 01-03-2013 12:40 PM
Toilet Dilemma rightit Plumbing 11 08-20-2011 08:29 PM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
