Fireplace Over Septic Field - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-31-2016, 05:54 PM   #1
Grizzle_Bo's Avatar
Rewards Points: 4
Fireplace over septic field
want to build a small fire place in my yard. Problem is I'm not sure that my drain field will be bothered by it. Does anyone know if it matters if I put a fire place on the drain field trenches or even if I decided the hell with the great grass and put it right at the leech field.?
Sent from my 831C using Tapatalk
Grizzle_Bo is offline   Reply With Quote
Old 05-31-2016, 07:00 PM   #2
Rewards Points: 18,794
Re: Fireplace over septic field
So far we have no drawings or pictures of exactly how big this fireplace is.
No location in your profile so we have no idea how deep the footings going to have to be to build it on.
No idea how deep the line is your planing on building over.
Old 05-31-2016, 07:14 PM   #3
An old Tradesmen
Rewards Points: 9,238
Moved to Plumbing forum.
Old 05-31-2016, 08:35 PM   #4
Grizzle_Bo's Avatar
Rewards Points: 4
Just a small fire place, with cement blocks, nothing fancy, no digging . . I believe the lines are 3 ft deep and 18 inches below ground.
Old 06-01-2016, 05:10 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 1,770
Not sure how to interpret "3 ft deep and 18" below ground" but it sounds like your proposal is pretty simple and shouldn't be a problem. I would caution if you a planning on building a fire on cement block (as opposed to using blocks as a perimeter). The fire will probably cause them to break.
lenaitch is offline   Reply With Quote
Neighbor Sump Discharge Saturating my Septic Field Angielynne Plumbing 25 05-24-2013 01:39 PM
septic field diverter valve - which field is which? denemante Plumbing 1 01-16-2013 09:46 AM
location of new septic field rkibler Plumbing 5 10-05-2010 01:55 AM
Septic Tank not flowing into leach lines or drain field michaelschier Plumbing 19 09-01-2010 07:58 AM
How do i fix/install septic tank drainage field? vcordon Plumbing 10 06-15-2010 10:20 PM
