Finish Work Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2015, 01:12 AM   #1
Rewards Points: 28
Finish Work Shower
I am finishing plumbing in bathroom remodel. Do I seal around the water head flashing where it touches the tile, and around the valve handle flashings where they touch the tile? If so, what type of caulk is recommended? Thanks.
Hoshwa is offline   Reply With Quote
Old 08-15-2015, 07:10 AM   #2
Retired Moderator
Rewards Points: 7,174
No---the shower arm is above the wet area---and the mixer cover has a foam gasket the keeps the water out of the wall---(some folks will use silicone caulk across the top if the tile is uneven)
Old 08-15-2015, 05:59 PM   #3
Trucon01's Avatar
Rewards Points: 510
I use this, just not at the very bottom. http://www.homedepot.com/catalog/pro...ad2a42_300.jpg
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 08-15-2015, 06:03 PM   #4
Trucon01's Avatar
Rewards Points: 510
Here is what mine looks like.
Old 08-15-2015, 06:04 PM   #5
Trucon01's Avatar
Rewards Points: 510
I use crystal clear because the other 'clear' formulas arnt truly clear, after a while.
Old 08-15-2015, 06:20 PM   #6
Rewards Points: 28
You seal around the cover plate itself? What is the valve needs work?
Old 08-15-2015, 06:30 PM   #7
Trucon01's Avatar
Rewards Points: 510
Its silicone. Unscrew and pull off. Then use a razor to scrap off caulk from tile. Do your work. Screw cover back on and recaulk
The Following User Says Thank You to Trucon01 For This Useful Post:
ProGreen (08-16-2015)
Old 08-15-2015, 06:31 PM   #8
Trucon01's Avatar
Rewards Points: 510
Caulk everywhere besides the bottom
Old 08-15-2015, 07:02 PM   #9
Rewards Points: 28
Confused. Last person said not necessary. You obviously do not agree. Can I ask if you are a plumber?
Old 08-15-2015, 07:06 PM   #10
Trucon01's Avatar
Rewards Points: 510
Nope. Not a plumber.
There is a foam gasket behind the cover, true. But if you tile is uneven, especially if you have grout lines withing the cover, thats why i used it. Plus i think it gives it a better looking finish.
Old 08-15-2015, 07:11 PM   #11
Rewards Points: 28
Thanks. Mine is against flat stone. Do you think I still need it?
Old 08-15-2015, 07:12 PM   #12
Trucon01's Avatar
Rewards Points: 510
If you post a pic, id gladly look at it.
Old 08-15-2015, 07:56 PM   #13
ZTMAN's Avatar
Rewards Points: 624
I am not a plumber either, but in my house I caulk to 5 and 7. Can only help and it wont hurt anything. I use a very small bead, just enough to hit the seam.
ZTMAN is offline   Reply With Quote
Old 08-15-2015, 08:58 PM   #14
Rewards Points: 1,930
The question that needs answered is will it hurt to caulk it with clear caulk? Or do we wait and see if the foam gasket is working?
The Following User Says Thank You to Ghostmaker For This Useful Post:
oh'mike (08-16-2015)
Need advice in fixing "contractor's" botched shower floor tile job toocheaptohire Tiling, ceramics, marble 6 04-19-2018 09:09 AM
Incompetent Contractor taking advantage ? (pictures) ford361 Kitchen & Bath Remodeling 11 06-21-2012 06:42 AM
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 12:00 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
