Finding A Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2015, 12:49 PM   #1
Rewards Points: 90
Finding a Drain
I am moving into a new house, and want to put a water softener. The only place I can put it is on the garage where the main water comes into the house, as the laundry room is too small.
There's one problem, the garage doesn't have a drain where the exhuast water can go. The ceiling is more than 8" as recommended by the manufacture recommend of maximum height to run a drain line and too far to push the water across, and I can't drain it outside because it will be an environmental problem.
Where is the best place to drain the water coming out of the water softner?
jesusq is offline   Reply With Quote
Old 12-10-2015, 03:52 PM   #2
Rewards Points: 18,794
Had the water tested to even know if you need a softener?
How is the drain from a softener an environmental issue?
Old 12-10-2015, 03:56 PM   #3
Rewards Points: 90
I'm moving within the same MUD district, and have own this softener and moved to a new home within the same district.
The waste water from the softener is harmful to plants and the environment. I don't want to kill the garden to the neighbor which is right next to the garage.
Old 12-10-2015, 03:56 PM   #4
Rewards Points: 5,348
Punch a hole in the garage wall and install a dry well for the water. Or use the water to water your lawn.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
joecaption (12-10-2015)
Old 12-10-2015, 04:09 PM   #5
Not sure where your getting that info or even what a "MUD" district is.
I own three houses, all with softeners, all drain to a drywall and the grass is always greener where they drain.
Your getting some miss information.
Old 12-10-2015, 04:33 PM   #6
Rewards Points: 90
This is a lessened learned. In my other home, I drained it to the side of the home, thinking like you, it would water the lawn, and learned my lesson.
Grass or plants don't like salt water in the long term, it would all die.
It's also stated by the manufacturer that the salt waste water needs to be drained and not dispersed out to the lawn.
Old 12-10-2015, 06:00 PM   #7
Rewards Points: 262
It's overkill for just a softener but you could discharge the softener into a sewage ejector and the ejector pump would push the water to your house drains.
Dan
djlandkpl is online now   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
oh'mike (12-10-2015)
Tags
water softner question
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Avoiding a frozen paver drain BrandonC_1972 Plumbing 2 04-28-2012 09:11 AM
Scupper drain installation advice needed miamicuse Roofing/Siding 9 02-11-2012 09:59 AM
Final drain test, tricks to finding the leak jdspace Plumbing 0 12-26-2009 10:52 PM
Needd Help Finding the right Drain collguy82 Plumbing 0 12-02-2009 12:42 PM
