Fiberglass Shower Pan Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By red73mustang
  • 1 Post By chandler48
Old 12-04-2017, 04:24 PM   #1
Rewards Points: 6
Fiberglass Shower pan replacement
So I'm re doing my corner shower and when removing the old fiberglass shower pan I have discovered that it was "glued in" with what looks like thinset? Was this a common practice in older houses? Needless to say its coming off in little tiny chunks of fiberglass.
The drain pipe is just a simple piece of PVC pip coming up from the slab floor which I imagin will need to have the thinset removed from it.
So what are my options when putting a new pan in as far as the drain part? (will those rubber type flanges fit over my PVC drain pipe assuming I can clean it up?)
Thanks, Chet
KYdiyer likes this.
red73mustang is offline   Reply With Quote
Old 12-04-2017, 05:09 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,700
Re: Fiberglass Shower pan replacement
Duplicate thread. We read them all.
Nealtw likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 12-08-2017, 05:40 PM   #3
Rewards Points: 6
red73mustang
-Seems like cleaning up the thin-set is the biggest issue. Some of those adhesives used for fiberglass can be nasty to deal with, try denatured alcohol, or mineral spirits to help remove and clean from your drain pipe. Let it soak in if possible.
Once the drain pipe is clean any shower drain should work. Look into an acrylic shower base and use something like builders felt under the base. As long as the pipe is a couple inches about the the drain hole in the base the rubber sleeve/gasket with the drain, along with nice bead if silicon should work well (if you do use a an acrylic base use silicone for the drain and not plumbers putty.
Gook luck!
KYdiyer is offline   Reply With Quote
How to remove brass drain flange from fiberglass shower pan scottyv81 Plumbing 21 09-23-2012 01:03 PM
Fiberglass base versus tile base shower Yakshower Kitchen & Bath Remodeling 2 03-18-2012 06:17 PM
Replacement Shower Escutcheon Jessidog Plumbing 3 11-27-2011 08:35 PM
Shower Arm Replacement - Please Help Detroitphan Plumbing 7 03-06-2011 10:52 PM
Shower door install in unplumb fiberglass surround screenporch21 Building & Construction 1 11-24-2008 02:36 PM
