A Few ?'s About Sewer Pipe Thickness And Insulation And Material - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-08-2016, 11:08 AM   #1
Rewards Points: 86
A few ?'s about sewer pipe thickness and insulation and material
I have a cast iron sewer drain that is cracking and needs replacement.
City says I can use PVC joined to CI, but the requirement is "shall be insulated to meet a 45 sound transmission class. For our purposes, what that means is every PVC drain has to be encased in 2 inches of closed cell foam insulation with a 2 pound density to quite the noise of water running through the drains"
The current pipe is 4" cast iron. I would like to go with PVC for material cost savings, but - correct me if I'm wrong - the insulation requirement would make the OD of the PVC thicker than the current cast iron? I don't think the wall would fit that.
What kind of material exactly are they referring to regarding the insulation? Is it a fiber glass? Can someone send me a link?
odie91 is offline   Reply With Quote
Old 04-08-2016, 11:13 AM   #2
Rewards Points: 86
Re: A few ?'s about sewer pipe thickness and insulation and material
i should add, if i have another way of metting the "45 sound transmission" class without needing 2" thickness of foam, i can propose such. if there are thinner more denser options that the foam (which i still don't exactly what that is), please let me know.
i will try to post pics if i can get my darn camera to unlock.
Old 04-08-2016, 11:30 AM   #3
Rewards Points: 1,528
Where are you from? That's requirement sounds ridiculous to me... but I guess it depends on where you are.. My sewer pipe is a good 5 feet underground... no noise to be heard from that thing...
ryansdiydad is offline   Reply With Quote
Old 04-08-2016, 11:32 AM   #4
Rewards Points: 86
i should have clarified. this is referring to the vertical pipe section on an inner wall within the house.
Old 04-08-2016, 11:56 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 180
Why not repair with cast iron?
Your code reference must be a local code. This is not a typical plumbing requirement. I would ask your code official for a reference document that satisfies the requirement.
Side note- sewers are typically exterior, while building drains are interior- at least in my neck of the woods...
Sloping a flat roof...with tiered insulation? Emiliano Roofing/Siding 7 01-18-2012 09:32 PM
Condensation in (yet to be finished) finished attic during spring chrisi Building & Construction 5 03-21-2010 02:55 PM
Shrink film window insulation, no kit EscarHolmez General DIY Discussions 3 12-28-2008 12:05 PM
