Faucet Pull-Out Hose - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-03-2016, 06:18 PM   #1
Rewards Points: 8
The pull-out faucet house in my kitchen sink is leaking. Went to HD to get a replacement kit and got one that "fits all faucet brands." However when I removed the old line - the connection don't look anything like any of the various adapters in the kit. Tried to identify the make of the faucet but nothing I can find. It might have come with the American Standard sink -- but not real way to tell. Anyone recognize or know where I might find a hose with the connections pictured?
The connection on the base has a little plastic switch the appears to release the external gray bracket around the connection while the other end of the hose just threads into the head.
As always -- thanks in advance.
Faucet Pull-Out Hose-20160601_084748.jpg   Faucet Pull-Out Hose-20160603_190059.jpg   Faucet Pull-Out Hose-20160603_190113.jpg   Faucet Pull-Out Hose-20160603_190727.jpg
gg1077 is offline   Reply With Quote
Old 06-03-2016, 07:42 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 1,776
Re: Faucet Pull-Out Hose
It looks similar to the Moen I recently installed (the former unit was leaking) but it is possible that many models of pull-outs use similar looking connections. You don't mention where it is leaking. If it is at the supply end of the flex hose, check the condition of the o-ring and/or seat washer. Maybe take it into a good hardware store - if it is a name brand, there might be a repair kit. If is the o-ring, you should be able to source a similar-sized replacement.
lenaitch is online now   Reply With Quote
Old 06-04-2016, 11:47 AM   #3
Rewards Points: 1,862
On the spout is the brand name engraved? If it is a moen the parts are fully warranted from moen.
Tags
faucet , hose , quick connect
New Kitchen Faucet Kathy642 Kitchen & Bath Remodeling 1 07-17-2015 06:52 AM
Hose coupler is fused to faucet bib. lionscourt Plumbing 16 07-03-2015 11:47 AM
Can't get kitchen faucet spray hose loose from supply line kkruecke Plumbing 2 04-19-2015 11:35 PM
Selecting a New Kitchen Faucet klumbsy Kitchen & Bath Remodeling 4 02-25-2011 08:29 AM
Low water pressure on Kitchen faucet DIY_user Plumbing 3 01-08-2010 12:08 PM
