Faucet Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-18-2016, 07:39 AM   #1
Rewards Points: 322
Faucet help
The cold side is leaking when I turn this on, I'd like to take cap/cover off so does anyone know how to get it off? I tried unscrewing it but it will not move and was afraid to put too much force on it as I'm uncertain that this is how it comes off and don't want to break anything since bathroom model is minimum one year off.
thank you
mske390 is offline   Reply With Quote
Old 10-18-2016, 07:58 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,514
Re: Faucet help
Should be a nut in the middle of the star handle.
Old 10-18-2016, 08:40 AM   #3
Rewards Points: 322
Re: Faucet help
There is a nut in middle of star handle to take that off, I should have mentioned that in original post. This has nothing to do with the cover I am trying to take off.
Old 10-18-2016, 09:06 AM   #4
Rewards Points: 322
Re: Faucet help
opps I should have mentioned that there is no set/lock screw on the cap/cover anywhere.
Old 10-18-2016, 02:48 PM   #5
Rewards Points: 3,492
Re: Faucet help
Handle has to come first, then run a blade around cover. Sometimes they are silicon or glued on.
jmon is offline   Reply With Quote
Old 10-18-2016, 08:07 PM   #6
Rewards Points: 322
Re: Faucet help
Yes everyone I realize that the handle has to come off, my apologies for not saying that I know and did that. How does the cover come off? Cover or whatever it is actually called will not come off, does it screw off or pull straight out? Guessing it screws as I don't see anything holding it down in place. thank you for any help
Old 10-18-2016, 09:42 PM   #7
Rewards Points: 80
Re: Faucet help
It's hard to tell from your picture, but they are probably siliconed on. They will likely feel like they won't come off at first, until the first tear starts. Then it's easy.
Of course, since you said there's no set screw, assuming that you've checked the bottom for one. (opposite to camera)
Cheers!
supers05 is offline   Reply With Quote
Old 10-19-2016, 08:10 AM   #8
Rewards Points: 322
Re: Faucet help
Yes first thing I did was check for set screw everywhere, nothing there. Tried to remove the two others figuring this one has some calcium built up so may be hardest but had no luck with them. As you can see they are old so realize are probably on there good but like I said before I start putting any kind of serious force want to make sure I'm not doing something that will break it. I'll grab my picks and see what comes about.
thank you
Old 10-19-2016, 08:16 AM   #9
Rewards Points: 6,580
Re: Faucet help
Relieve the bond by pushing a double edge razor blade with a pair of pliers. Less chance of damaging the tile.
SeniorSitizen is offline   Reply With Quote
Old 10-19-2016, 08:57 AM   #10
hkstroud's Avatar
Rewards Points: 6,694
Re: Faucet help
Pretty sure that those escutcheons (covers) screw off. As others have said, run a utility knife around the edge to insure that any caulking or silicone has been separated. Then turn counter clockwise. Use a strap wrench (on the edge next to the wall) if your grip is not strong enough.
hkstroud is offline   Reply With Quote
Old 10-19-2016, 08:00 PM   #11
Rewards Points: 322
Re: Faucet help
Hkstroud thank ˙ou for answering the question that I asked. I finally got it off it didn't screw off, apparently they do not make these valves anymore so I found a $3 gasket that fit. Reassembled no leak!
Old 10-19-2016, 08:17 PM   #12
hkstroud's Avatar
Re: Faucet help
I just finished Googling around trying to confirm that what you have is American Standard. Granted "old" American Standard, from the 1950's.
See, I can remember that far back.
Guess what, parts can be found.
https://deabath.com/Faucet_and_Fauce...ower_kits.html
Old 10-20-2016, 12:19 AM   #13
Rewards Points: 80
Re: Faucet help
They aren't cheap, but wow! Cool find!
Cheers!
Old 10-20-2016, 06:50 AM   #14
Rewards Points: 322
Re: Faucet help
Ugh just read my last response and typo...meant to say that it "did" screw off not didn't.
Great find hkstroud thank you, I'll take a look at link. Bathroom will be renovated but just not certain of when, need to do kitchen first (please let this be a good bonus year).
Old 10-20-2016, 08:39 AM   #15
hkstroud's Avatar
Re: Faucet help
Thanks. I was beginning to wonder about my memory.
pressure and shower faucet rob613 Plumbing 2 04-18-2013 12:07 PM
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 08:45 AM
Selecting a New Kitchen Faucet klumbsy Kitchen & Bath Remodeling 4 02-25-2011 08:29 AM
Ice in Cover over Exterior Faucet SPetty General DIY Discussions 13 01-11-2010 03:32 PM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 01:25 PM
