Faucet Drip - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By ZTMAN
  • 1 Post By TimPa
Old 03-08-2017, 10:20 AM   #1
Rewards Points: 1,005
faucet drip
have a delta waterfall (14 yr old) faucet that started a drip couple of years ago. of course went through the replacement of springs/washers, then entire cartridges - all several times. using actual delta parts. and the drip seems to always return after a few months.
any advice appreciated.
TimPa is offline   Reply With Quote
Old 03-08-2017, 10:48 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,248
Re: faucet drip
Ayuh,... Sounds like something is scratched, or worn out,...
I'd just slap in a new set of faucets,...
The Following User Says Thank You to Bondo For This Useful Post:
TimPa (03-08-2017)
Old 03-08-2017, 11:16 AM   #3
JUSTA MEMBER
Rewards Points: 3,882
Re: faucet drip
I would be checking on any lifetime warranty.
Because something has probably wore a groove in there that simply changing parts wont fix.
Water will erode anything if the water is even partially hard ( minerals).
I don't know off hand if Delta is one of those with lifetime warranties, but if they do, they will replace it for you.
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
TimPa (03-08-2017)
Old 03-08-2017, 11:46 AM   #4
Rewards Points: 6,430
Re: faucet drip
Have you tried Delta's help line in an attempt to solve the problem. They seem willing to solve most problems.
https://www.deltafaucet.com/service-parts
If your faucet is a single handle I can't help unless your water is well water and pumps a little sand. If it is a 2 handle I do know the spring is tapered and directional. The small end goes into the seat.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
TimPa (03-08-2017)
Old 03-08-2017, 12:44 PM   #5
ZTMAN's Avatar
Rewards Points: 628
Re: faucet drip
Did you put plumber's grease on the new o rings when you installed them?
SeniorSitizen likes this.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
The Following User Says Thank You to ZTMAN For This Useful Post:
TimPa (03-08-2017)
Old 03-08-2017, 01:42 PM   #6
Re: faucet drip
great tip on the help line, and the possible warranty. it is a 2 handle. pretty sure there are no other parts touching the cartridge and washer/seat. I do grease them. thanks all.
de-nagorg likes this.
Old 03-09-2017, 01:02 AM   #7
Rewards Points: 38
Re: faucet drip
NEVER grease Delta rubber seats. O-rings OK with silicone grease. Do not use petroleum-based plumbers grease on any rubber (or plastic) parts. NOT the seats though, leaks will often result.
SHR Plumber is offline   Reply With Quote
Old 03-09-2017, 06:11 AM   #8
Re: faucet drip
didn't know that. any lubrication?
Old 03-09-2017, 06:34 AM   #9
hkstroud's Avatar
Rewards Points: 6,694
Re: faucet drip
I'm contused. Does this faucet have cartridges or washers and seats?
Show picture of stem or cartridge.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 03-09-2017, 12:52 PM   #10
Re: faucet drip
like this, sorry if I misused terms, not a plumber. does it show?
Old 03-09-2017, 02:11 PM   #11
ZTMAN's Avatar
Rewards Points: 628
Re: faucet drip
Couple of you tube videos. Are you sure you are installing the seats and springs correctly?
You may be putting them in back wards. Plus, you should be using silicone grease, not petroleum based.
Old 03-09-2017, 05:08 PM   #12
Re: faucet drip
I notice in the dual handle vid there was no mention of the seat spring being directional. Delta help line told me , definitely without stuttering , small end into the seat. Does it really make any difference?
Old 03-09-2017, 06:02 PM   #13
ZTMAN's Avatar
Rewards Points: 628
Re: faucet drip
I assume they taper them at one end for a reason. If the OP is experiencing problems after a few months after installation, something is giving way. Could be something is in backwards. Never tried to install them wrong, so I don't know if it would make a difference but seems like it could
Old 03-10-2017, 06:45 AM   #14
Re: faucet drip
been doing it just like that. I don't think you can put the large end of the spring into the rubber can you?
but I have been using petroleum based grease for sure. will have to pick up some silicon... thanks.
Why Does My Laundry Faucet Only DRIP In Winter? How To Resolve? Sean Price Plumbing 6 01-14-2017 09:21 PM
Bathroom Drip Delta Faucet Woody10 Plumbing 4 10-16-2015 07:30 PM
Very slow tub faucet drip MikeyChris Plumbing 1 07-21-2014 09:39 AM
Very slow drip under counter from faucet EricBNeverScare Plumbing 28 04-18-2013 07:20 PM
New Moen Faucet still has sloooooow drip straightsix Plumbing 4 11-05-2012 08:51 PM
