Fastening Pvc ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-18-2015, 07:21 PM   #1
Rewards Points: 1,364
fastening pvc ?
i am doing the rough in for my washer. i am placing the pipes inside the wall cavity. what i need to know = how do i secure the pipes to the 2x4's ? they will be right next to the 2x4's. thanx
Fix'n it is online now   Reply With Quote
Old 06-18-2015, 07:26 PM   #2
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,712
https://www.google.ca/search?q=pvc+p...Q&ved=0CBwQsAQ
123pugsy is offline   Reply With Quote
Old 06-18-2015, 07:57 PM   #3
thanx. i would not have thought to call them clamps.
Old 06-18-2015, 08:20 PM   #4
Property Mgt/Maint
Rewards Points: 8,202
or
http://www.oatey.com/doc/Plastic%20Hanger%20Strap.pdf
[political signature removed]
Yodaman is offline   Reply With Quote
The Following 2 Users Say Thank You to Yodaman For This Useful Post:
123pugsy (06-19-2015), Fix'n it (06-18-2015)
Old 06-18-2015, 10:59 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 302
Good 'ol fashion P-tape.....
Old 06-19-2015, 04:21 AM   #6
123pugsy's Avatar
Never heard of this P tape???
Old 06-19-2015, 05:29 AM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 908
Plumbers tape.
Kind of a misnomer. It is plastic or steel strapping with holes every inch.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
Old 06-19-2015, 06:48 AM   #8
123pugsy's Avatar
Originally Posted by rjniles View Post
Plumbers tape.
Thanks.
Inspector told my HVAC guy to use some kind kind of gasket between the steel strap and the PVC exhaust pipe. I like the idea of the plastic. Never seen it before. Is it strong or king of soft and stretchy?
Old 06-19-2015, 07:09 AM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 908
Strong and doesn't stretch.
Old 06-19-2015, 08:33 AM   #10
Plumber
Rewards Points: 302
nobody around my area uses plastic strap. It's either p-tape or occasionally Ape Tape.
Based on code I've read- plastic could not be enforced.
Old 06-19-2015, 08:36 AM   #11
A "Handy Husband"
rjniles's Avatar
Rewards Points: 908
Now you got me, Ape Tape?
Gorilla Tape?
Old 06-19-2015, 09:00 AM   #12
Plumber
Rewards Points: 302
Gorilla Tape?
I couldn't help myself
http://www.siouxchief.com/products/s...-strap/apetape
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
123pugsy (06-19-2015), rjniles (06-19-2015)
Old 06-19-2015, 09:42 AM   #13
Special User
Rewards Points: 1,230
Interesting. I'd be afraid that metal tape would eventually wear a hole in plastic pipe. I use the white plastic tape, but of course, I'm not a pro.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 06-20-2015, 07:36 AM   #14
thanx guys. i couldn't find anything at the store. i already have some metal plumbers tape. i will use that.
The Following User Says Thank You to Fix'n it For This Useful Post:
Ghostmaker (06-20-2015)
Cure time before fastening n0c7 Concrete, Stone & Masonry 23 05-16-2013 03:32 PM
Fastening to 1/8" steel Toller Building & Construction 14 05-13-2013 02:40 PM
I&W around pipes and valley metal fastening diyroofer Roofing/Siding 0 09-12-2011 05:39 PM
Fastening Azek Trim joetab24 Building & Construction 13 08-15-2011 06:23 PM
Fastening structural beams PaddyHutch Building & Construction 3 01-11-2009 09:58 AM
