Failed Plumbing Rough In? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2016, 07:38 AM   #16
WhatRnsdownhill's Avatar
Rewards Points: 2,220
Originally Posted by apriliaalex View Post
What's an inspector?
many times its a guy that got a job from knowing someone and not something.............with a big ego..........
WhatRnsdownhill is offline   Reply With Quote
Old 01-23-2016, 01:25 PM   #17
Rewards Points: 1,852
Maybe in NY.
Old 01-23-2016, 02:13 PM   #18
definitely in ohio..so you still didnt answer if you were ever a licensed plumber..still waiting for that..just because your an inspector that can quote out of a code book doesnt mean squat..
Old 01-24-2016, 10:54 AM   #19
Rewards Points: 2
Hello all and thank you for the replys. I'm in NC as far as code, but also that means I haven't had power for a few days. I'll respond to the questions and provide more detail about the job once I get everything up and going around here.
ngrimm is offline   Reply With Quote
Old 01-24-2016, 12:11 PM   #20
In Ohio I was a licensed plumbing contractor. Yet you apparently a troll of the worse kind. We also require Ohio plumbing inspectors to have 8 years verifiable trade experience prior to the test. Which usually only 33 % pass. I also hold a Medical Gas inspectors license. Yet you have yet to even post your first license. Since you do not know the DFU of a Kitchen sink I got to wonder..
Old 01-24-2016, 12:28 PM   #21
Rewards Points: 582
well it may not mean squat...however put a plumbing system in that dosen't meet code...and I'll bet it will mean something to you then....
Old 01-24-2016, 12:32 PM   #22
my plumbing passes inspections, unlike what to op has posted...so I dont worry about inspections..
Old 01-25-2016, 02:44 PM   #23
Rewards Points: 2
Jack and Jill upstairs
Old 01-25-2016, 05:31 PM   #24
The lower toilet Just cut in a 3 by 2 wye and run towards the lav with a vent and pick up the tub along the way. Your turn down need to become a normal 3 inch 90.
The upper toilet is fine The lav is your wet vent provided it is vented.
Installing Plumbing in a basement with No rough ins simpsjm1 Plumbing 8 12-20-2011 10:40 PM
basement plumbing rough in smacameron Plumbing 3 11-20-2011 05:34 PM
basement plumbing rough in - what are these pipes? skypilot84 Plumbing 1 10-12-2010 11:59 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
Plumbing rough design rdcusmc Plumbing 19 06-08-2009 09:29 PM
