Extreme Banging And Rattling Of Copper Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2015, 07:05 PM   #1
Rewards Points: 4
Question
Extreme Banging and Rattling of Copper Pipes
All the water lines were fine when we started to remodel this house. Everything worked.
All pipes are copper.
1 . We disconnected a hot and cold water line that went from the basement to the first floor that was used for a washing machine. We cut them off in the basement and capped them. There was a washer/dryer hookup in the basement so we wanted to use them instead.
2. We disconnected a hot water tank in the basement and capped the line. The hot water is now running off the furnace.
The shower and tub were working fine.
NOW, after removing what we did, when we use the shower/tub (which has a one handle American standard mixing value) makes all the pipes BANG / RATTLE AND VIBRATE. IT IS EXTREME AND YOU CAN SEE ALL THE PIPES IN THE BASEMENT MOVING.
It ONLY happens when we MIX the hot and cold.
It should also be noted that if we use just the cold or just the hot, it does not happen.
We have tried replacing the cartridge and that did not work.
There is also REDUCED FLOW in the COLD WATER LINE ONLY in the shower/tub.
ANY THOUGHTS? WE ARE OUT OF THOUGHTS!
Niantic is offline   Reply With Quote
Old 08-04-2015, 07:57 AM   #2
Rewards Points: 3,428
Probably some debris or a pebble got into the water line and lodged at the shower faucet assembly.
Does the faucet assembly have other moving parts not in the cartridge? One of those could be defective.
Does the problem happen both with using the shower and using the bathtub spout?
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
