Exterior Faucet Leaking From The Top - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-26-2015, 06:37 PM   #1
Rewards Points: 77
Exterior Faucet leaking from the top
I have an exterior faucet that when turned on, leaks from the top where there is a hole with some sort of plug/bolt in it. I removed it and took a look and took it the local hardware store, but they were clueless. The rubber washer inside was intact but put a new one on anyways but it made no difference. I attached some pics and a video of my problem. It is a frost free faucet if that makes a difference.
No idea how to embed a video...
https://youtu.be/p9VLSZgWEQA
elementz is offline   Reply With Quote
Old 05-26-2015, 07:50 PM   #2
Rewards Points: 3,430
One of the plumbers will be along soon they will know what type of frost free hose bib it is.
Not really sure if that's some sort of a vacumm breaker or bleeder on top. If it's a vacumm breaker it may need to be replaced/rebuilt. Have to get the correct rebuild kit for it. Never seen one like that.
Did you possibly overtightened, crack or cross thread it? Looking at your video, the water really gushes out of it pretty good.
jmon is offline   Reply With Quote
Old 05-27-2015, 05:49 AM   #3
Rewards Points: 77
The house was built in 2002. The video in the OP shows without the plug/bolt. When it is on, the water will come out as a slow trickle from the top and will flow out normally from the downspout
Leaking Milgard vinyl windows (occasionally) lazzlazz Windows and Doors 14 08-08-2015 02:40 PM
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 05:00 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 04:40 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 04:43 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
