Exspansion Chambers - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-25-2016, 03:45 PM   #1
Exspansion chambers
A few years ago, I roughed in the plumbing in a house for my boss.
(His house - new)
He decided to add a bath on the second floor.
He took the supply lines off of the expansion chambers on the vanity,
from one of the baths on the first floor.
Good idea or not?!?
Thanks!
rossfingal
(Happy Spring - y'all!!!)
rossfingal is offline   Reply With Quote
Old 04-25-2016, 03:49 PM   #2
Civil Engineer
Rewards Points: 5,246
Re: Exspansion chambers
What is an expansion chamber, and why do you have one on a vanity?
Old 04-25-2016, 04:08 PM   #3
To try to prevent "water-hammer", from happening.
"Banging" sounds - when you turn on and off the water.
rossfingal
Old 04-25-2016, 06:43 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 168
There is an argument that says the air escapes the air chambers over a period of time and need to be recharged by draining the water system. Whether it's true or not- I don't know.
I have only installed manufactured water hammer arrestors and my state has amended the UPC to exclude arrestors on residential work- so my experience with home made ones is limited. But, I see little reason to have them on a lav. Perhaps an ice maker or washer though
If it has been a while, and there is no hammering- I'd say it's all good...
The Following User Says Thank You to TheEplumber For This Useful Post:
rossfingal (04-26-2016)
Old 04-27-2016, 08:34 AM   #5
Rewards Points: 3,282
For homemade water hammer arrestors, consisting of a tee to a seemingly useless vertical pipe capped at the top, the air inside will be gradually absorbed by the water thus needing recharge by draining the water system.
Once in awhile the water supply has air bubbles which under favorable conditions can replenish the air in the arrestors faster than air gets absorbed.
Manufactured arrestors have a spring, piston, and/or bladder so as not to need recharging.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
The Following User Says Thank You to AllanJ For This Useful Post:
rossfingal (04-27-2016)
Chambers Stove Problem roobinsteen Appliances 8 05-31-2016 06:07 AM
Feed Experimental chambers cold water HVAC Designs Plumbing 0 03-20-2013 05:06 PM
Chambers cooktop range carpdad Appliances 1 01-14-2013 02:44 PM
septic field chambers denemante Plumbing 1 01-08-2013 03:18 PM
Air Chambers II Weeks Plumbing 1 02-24-2009 07:26 PM
