Expansion Tank, Is This Correct? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-22-2016, 12:06 AM   #1
Rewards Points: 101
Expansion tank, is this correct?
My previous house, which we know rent out and during an inspection we were told to get the expansion tank fixed and add another seismic strap to the water heater. The strap is no problem but can anyone see an issue with this expansion tank?
Expansion tank, is this correct?-img_1190_1458623025577.jpg   Expansion tank, is this correct?-img_1189_1458623045564.jpg
mikereno1 is offline   Reply With Quote
Old 03-22-2016, 06:19 AM   #2
SHEPLMBR's Avatar
Rewards Points: 178
Re: Expansion tank, is this correct?
Am I correct in what I am seeing. You piped from cold into tank then into the hot side of water heater?
SHEPLMBR is offline   Reply With Quote
Old 03-22-2016, 08:30 AM   #3
Rewards Points: 3,290
It is better if the expansion tank has some additional support from below or some suspension from above. The strap is correct but should not need to be tightened ever so tight so as to keep the expansion tank from sliding down and out.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
Old 03-22-2016, 08:45 AM   #4
Rewards Points: 106
ask the inspector what the problem that needs tobe fixed is..
goobertime is offline   Reply With Quote
Old 03-22-2016, 09:27 AM   #5
Rewards Points: 101
No, cold into expansion, into cold side of hot water heater. Hot side of heater goes out to the bathrooms, etc
Old 03-22-2016, 09:36 AM   #6
Rewards Points: 101
I'm waiting on a call back from him. The report reads "Water heater missing proper bottom seismic straps and expansion tank. Consult licensed plumbing contractor to view and repair as necessary."
Old 03-22-2016, 11:05 AM   #7
Rewards Points: 3,230
I agree, wait and ask him and get clarification. Its possible he may have somehow overlooked it.
jmon is online now   Reply With Quote
Old 03-22-2016, 12:44 PM   #8
ZTMAN's Avatar
Rewards Points: 606
My guess would be he was too quick with his cut and paste while he was doing his report , and it should state:
"Water heater and expansion tank missing proper bottom seismic straps Consult licensed plumbing contractor to view and repair as necessary."
ZTMAN is offline   Reply With Quote
Old 03-22-2016, 02:43 PM   #9
Rewards Points: 2,560
Is there a seismic strap on bottom portion of the WH or just the top? They evidently need two; one top and one bottom.c
http://www.lowes.com/pd_272815-143-K...d=3191041&pl=1
bob22 is offline   Reply With Quote
Old 03-22-2016, 06:47 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 186
WH needs seismic strap at the top 1/3 of tank and bottom 1/3 of tank- this is assuming your're in a zone that requires seismic support.
Expansion tank is fine.
Old 03-22-2016, 06:50 PM   #11
Rewards Points: 101
Just the top strap right now, so I assumed he just wanted the lower added, but the expansion tank confused me. Cant imagine the expansion tank needs an upper and lower strap
Old 03-24-2016, 11:10 AM   #12
Rewards Points: 1,866
With the flexible connections to the tank yes the expansion tank needs strapped. And if you used PVC on the T&P relief I would have turned that down also.
well pressure switch NJ Lady Plumbing 32 12-16-2013 03:48 PM
Fil-Trol expansion tank maddog1 Plumbing 2 12-19-2012 04:58 PM
Old expansion tank leaking Ultrarunner2017 HVAC 7 11-16-2011 06:40 AM
Expansion Tank handy man88 Plumbing 5 05-11-2011 08:00 PM
Installing a new boiler expansion tank CoachDad HVAC 0 01-06-2010 01:12 PM
