Expansion Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2015, 09:23 AM   #16
Rewards Points: 58
Originally Posted by AllanJ View Post
Is that expansion tank tethered so it could not slide off of the top of the water heater?
No, the only thing keeping it there is the cpvc. I believe the tank manufacturer (Wilking) requires at least a strap to hold it in place. It is no where near what I saw in the model home. They tell you everything is to be built to code but they will use the cheapest, even if its at the cost of a $10-20 support. I'm suprised that it not being straped inplace isn't against code. Codes are suppost to protect the people purchasing the property from shotty installs that could cause possible injuries or damage to their property.
Big Cat is offline   Reply With Quote
The Following User Says Thank You to Big Cat For This Useful Post:
jmon (02-11-2015)
Old 02-11-2015, 11:00 AM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 290
My inspectors would not pass that due to possible lateral pipe movement. If the tank is secured then no issue.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Big Cat (02-11-2015), jmon (02-11-2015)
Old 02-11-2015, 02:18 PM   #18
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,312
Ayuh,.... I ain't a Plumber, 'n don't know squat 'bout codes, but I'd be embarrassed by that whole installation,...
The Following User Says Thank You to Bondo For This Useful Post:
ben's plumbing (02-11-2015)
Old 05-30-2015, 10:07 PM   #19
Rewards Points: 58
Follow up question about expansion tank
I'm not sure if it would be an issue if tank is laid on it side or installed below the cold water line. Would anyone think if the bladder failed (and most homeowners would never check much less know what the tank is) is there a chance for bacteria to build up in the tank if it can't empty out after a long period of time? I would want the tank hung where it could drain on its own if the bladder failed. Am I over thinking this?
Old 05-31-2015, 06:47 AM   #20
Rewards Points: 1,952
If the bladder in the tank fails then there is no longer any expansion of hot water. Normally the T&P on the hot water tank will start to drip.
Old 05-31-2015, 10:38 AM   #21
Rewards Points: 58
Thanks, Ghostmaker. That makes sense. Appreciate your input.
Expansion Tank jagans Plumbing 12 06-03-2013 12:29 PM
Question re draining heating expansion tank Rav HVAC 4 11-19-2012 09:53 AM
Expansion tank size problem Austin83 Plumbing 7 11-16-2012 07:58 AM
Old expansion tank leaking Ultrarunner2017 HVAC 7 11-16-2011 06:40 AM
Is a Hot Water Expansion Tank required Needagameplan Plumbing 9 04-27-2010 03:09 PM
